Posted 25 May 2024 - 04:41 PM
Posted 25 May 2024 - 07:16 PM
Posted 26 May 2024 - 08:11 PM
Know the pain with lining doors up, took the three of us a good evening to get them refitted, came off a doddle, worst bit I couldn’t ask Dad for advice aha.
The club had a set of hinges done back in the day, know we’ve got a spare set. How did you find the door fit?Dad always slammed the door to shut, I trimmed down the seal and then used foam on the door itself to seal it, seems to hold up ok! Bet you can’t wait to get it on the road, one of my Minis bright orange and if I had a Midas it would be that colour aha
The doors haven't been on for several years so I am struggling to remember the basic details such as fit. I seem to recall that (much like my school reports) there was "room for improvement"! My hinges are pretty much bang on - they needed a soak in oil for a week or so to get them moving properly again, but they're big hardy beasts so shouldn't be an issue. And as much as this wee orange beast annoys me, no you can't have it
Posted 26 May 2024 - 09:31 PM
Posted 02 June 2024 - 08:11 PM
Posted 13 June 2024 - 04:32 PM
Posted 15 June 2024 - 09:19 PM
Posted 16 June 2024 - 02:50 PM
Posted 12 July 2024 - 09:55 PM
Posted 14 July 2024 - 08:10 PM
Posted 31 August 2024 - 08:36 PM
Posted 12 October 2024 - 07:10 PM
Posted 13 October 2024 - 09:37 PM
It's looking good and I guess that by next Spring you should be mobile!
Posted 15 October 2024 - 03:35 PM
It's possible John, but I won't confirm that!
A quick little update for you. Tink left me a small list of things to do, so I have started going through it.
Number one was that the wiper wires needed to be joined up to the plug he'd left me. Out came the solder, the iron and the heatshrink. I had to shorten one of the wires due to a bit of corrosion, but once past that initial inch or so, it was beautiful copper again, and took the solder with no problems. I also needed to sort a longer earth cable. That was easy.
Number two really was a number two. Tink had advised me that the ignition switch was somewhat faulty. He did say it could be taken apart to attempt a fix, but there would likely be a question mark over whether it would work properly. Given it had been in the car (and standing pretty much since 1999), it was an easy decision to spend a little bit and get a brand new one. This has been ordered and it should turn up tomorrow, should the delivery e-mail be believed. The issue then was removing the current switch. Unfortunately these are fitted using shear bolts, and there are various "work-arounds" that profess to get the stubs to turn. Unfortunately the remains of the bolts are in a shrouded area, which makes it virtually impossible to "grind a slot into the bolt stub", even using a Dremel. Another suggestion is to use a punch to gently tap the bolts round so they undo. I chose this as my initial solution. This had one specific effect: it made me swear, and produce appropriate anger that I downed tools and went inside for a bit of a think.
Once I reappeared, there was a third option. I was getting a new switch. Therefore I didn't need the old one. Grinning maniacally, I grabbed the angle grinder with a cutting disc, and a few minutes of careful use saw the old switch off in pieces. Examination of the old bolts showed that I'd have really struggled to "tap it round"; there was corrosion on the threads which had basically adhered the screw to the housing. I guess 25 odd years of neglect does that to a key switch. I will continue once I have received the new one.
Wiper wiring now connected, soldered and heat shrunk. I've tidied the wiring up since the picture was taken.
The remains of the key switch after it met my friend the angle grinder...
And one of the bolts which showed a bit of corrosion, meaning it would NOT move. It ain't gonna move now!
Edited by MrBounce, 15 October 2024 - 03:38 PM.
Posted 16 October 2024 - 02:54 PM
Another quick update which is heavier on the pictures. Came back from taking Mrs Bounce to the opticians after she bent her glasses (no, I didn't sit on them...) and had received an e-mail to say my "Royal Mail parcel has been left in your safe place". Apparently my safe place is just dumped on the doorstep. Thankfully nobody had nicked it, and if they had, they would doubtless have been a bit disappointed if they were expecting a smart speaker or something electrical.
So into the garage I went, and gave the lock mechanism a squirt of some special lock lubricant my friend Ray had given me (he used to be a locksmith). Why? The mechanism felt a bit "sticky", most likely because it had been sat on a shelf in a warehouse for a bit. And before tightening up those bolts, I remembered to line it up with the plastic covers first. It would have been a bit galling if I'd forgotten to do this... Once I'd established that everything was correctly aligned, i tightened everything up, and of course, the shear bolts did their thing. It's my intention to never move it again!
Here is a box, a musical box, wound up, and ready to play. But this box can hide a secret inside - can you guess what is in it today?
One of Lucas' finest ignition switches, complete with 2 keys.
The key switch was a touch notchy - so I gave it a blast of this and it's now as smooth as silk. Cheers Ray!
I lined it up with the cowling, before...
...tightening up the shear bolts, which, unsurprisingly...
...did this!
