Project Zippy - Mk1 1981 Midas Project.
806 replies to this topic
#256 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 January 2015 - 03:22 PM
You can do it!!!
It will be fine in the end mate :-)
#257 MrBounce
MrBounce
  • 2,686 posts
Posted 04 February 2015 - 08:07 PM
Thank you Ben! Encouragement is always a good thing :thumbsup:
I stayed away from the garage for a few days to think about the top rail. Am still thinking... Went I went back in I realised I needed to clear up the workbench (again) as it was such a state. This meant finishing off rebuilding the carb, which I had put to one side when I had my bearing issues. When I took it apart, I had painstakingly taken photos of where the springs were. Since then, we have changed computers and I cannot find where the file is. So after an SOS call to the Mini Forum, a very kind chap provided me with some pics (Thanks Stu!).
As the engine isn't a massive state of tune, I haven't done anything special to the carb other than clean the innards and use a service pack as I did not know its previous life. Given the state of the rest of the engine, I reckon it'd been sat in a box for several years. I have replaced the needle with a BDL item as the engine is a very similar state of tune to the MG Metro - it should be a good starting point. The outside is not particularly shiny - in fact it's a bit grubby & pitted but I don't really mind - the insides are beautiful. This car has been built to use, not show, and spending several hours polishing bits won't make it go any faster - 'tis a functional piece of kit! Now all I need to do is fit it to the manifold and chuck on throttle and choke cables. Success!
Slowly going back together with new BDL needle (Apologies for rubbish photo).
New throttle disc screws applied and split. I didn't want bits of the old ones going down the inlet...
Carb is finished, if a bit scruffy. Really nice inside though!!
Edited by MrBounce, 04 February 2015 - 08:08 PM.
#258 Udo
Udo
  • 1,670 posts
Posted 05 February 2015 - 01:16 PM
Surely can't be long before you start bolting all these parts back together?
Any more work to do on the shell?
#259 MrBounce
MrBounce
  • 2,686 posts
Posted 05 February 2015 - 05:26 PM
Ian the plan is to have everything ready to be pretty much bolted back in - all about the prep! I still need to rub the bodywork down and give it some more coats plus I haven't started on the doors yet... There is much more to be done! O_O
#260 MrBounce
MrBounce
  • 2,686 posts
Posted 08 February 2015 - 05:14 PM
Had a pretty busy weekend so haven't had much garage time. I have however managed to grab an hour or so and started on a couple of small jobs. The abutment bracket for the carb (and the spacer) were pretty disgusting having sat in a box with other bits for quite a while. I have given them both a clean up and also a coat of primer. I just had enough to do 2 coats and the primer ran out. Got my money's worth out of that can...
I also had a look at the heater valve that I'd got from Guessworks on eBay (cheers John!). The valve itself works perfectly - it just had a bit of surface rust and fine covering of radiator silt on the inside. I split the two bits and cleaned up the metal using a wire brush. There are a couple of pockmarks from the surface rust so a quick blow-over with some satin black and a smear of grease should keep it in fine order. The valve itself will go in with the nest load of washing up. Plastic parts always seem to respond well to warm soapy water! More soon.
Abutment plate and spacer in primer. Platinum silver coat to follow.
Heater valve in its component parts - a bit rusty and dirty.
Valve mechanism cleaned up. Platinum silver or satin black? Hmmm...
#261 MrBounce
MrBounce
  • 2,686 posts
Posted 15 February 2015 - 02:34 PM
Back to garage and a few more little jobs done. It doesn't look much but it's the little things take time. The carb is now finished and has been put "together" with the inlet manifold, spacer and abutment plate for safe keeping. I have sprayed the metal part of the heater valve (no pictures yet) and have also primed and sprayed the spreader plates I made for the front subframe rear mounts. I also took the time to paint my front hubs. I had put them to one side ages ago meaning to do it and never got round to it. There was also a balljoint that I wasn't 100% happy with so I re-shimmed it and now feel satisfied. The hubs themselves are not perfect but anything is better than the rusty brown they were!
Last of all I have grabbed the driver's door in order to recondition the window winding mechanism and door locks. I will leave the picture of it to amuse everyone. It's a state, and this is the good one...
Carb is finished all bar cables and gaskets.
Spreader plates primed...
...and painted.
Hubs painted and looking a bit more presentable.
Driver's door internals. Not looking too good at the moment...
#262 MrBounce
MrBounce
  • 2,686 posts
Posted 24 February 2015 - 06:21 PM
A quick update as I had an hour or two after work this evening. The driver's door needed to be stripped and the first thing I needed to do was to release the window. I used the tried and trusted method of jamming the glass with a block of wood whilst winding the winder down to take the channel off the glass. Some hope. Seized solid. So out came the WD40 and a small hammer. A few taps with a flat blade screwdriver got it moving and it eventually popped off. I will be removing the frame eventually as I will need to replace the window seals but this may take some time so don't hold your breath!!
I then had to remove the plate which holds all the winding mechanism. This was held in place by about a dozen rivets. A few minutes with a drill and they were all out although they did fight a bit. I unhooked the door release mechanism and then withdrew the plate and the window winding gubbins. Unsurprisingly, the winder mechanism was covered in surface rust (as was the plate). I cleaned up the winder mechanism using the wire brush attachment on the angle grinder, masked off the greasy areas and gave it a coat of primer. I shall make sure it looks a lot better when it goes back in.
I am not sure whether to de-rust the plate or make a new one yet; there's only one section of it which looks horrid. However I don't have much steel and if I can get away without making it all the better. On the other hand, the passenger side plate is virtually see-through in places so I might do this one as practice for the other...
Channel removed. I had to hammer it off.
All rivets drilled out, plate removed.
Winder mechanism cleaned, masked and primed.
Edited by MrBounce, 24 February 2015 - 07:35 PM.
#263 MrBounce
MrBounce
  • 2,686 posts
Posted 25 February 2015 - 09:25 PM
Today I have mostly been playing with metal plates. First job was to see a) how bad the rust was and b) if it didn't appear to be too bad, I should try to remove it. First job? Out with the angle grinder and wire brush and I cleaned up the plate as best as I could. Although the plate looked quite bad, it appeared that the majority was surface rust. A few minutes' judicious use of the loudest tool I have and most was gone, and seemingly only a couple of minor pinholes had shown themselves. Perhaps I was going to be lucky? The next tool in my box was a chemical-based one - Bilt-Hamber's De-Ox gel. I only have one word for this stuff - astonishing. I brushed it on, left it for half an hour and then used a hand-held wire brush to agitate it all into a horrid brown sludge. This is then wiped off and viola! The rust has disappeared. Sadly it also revealed more pinholes and pockmarks than I could shake a stick at.
I am currently looking into places to get a decent amount of steel for as little money as possible. I guess it's cardboard template time... To calm myself I gave the winder assembly a coating of satin black which made it look all pretty.
Rusty. Here's hoping I can make it look a little more useable.
Potentially still useable - time for De-ox gel to really make sure!
Gel on. It really is amazing stuff.
Most of the rust just wiped off after agitation. Still some left, but it had told me all I needed to know...
...that holes like this are too bad to ignore. It's template time. Pass the new steel...
Still, at least the winder mechanism looks good now!
#264 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 February 2015 - 09:30 PM
Good stuff my man
#265 Udo
Udo
  • 1,670 posts
Posted 26 February 2015 - 12:47 PM
Good work Dave, Can you remake the plates in aluminium as easier to make and wont then rust in the future?
#266 Archived1
Archived1
  • Archived
  • 619 posts
Posted 01 March 2015 - 11:32 AM
Just read this whole thread. Its a great project!
Many would have given up long ago. Keep at it mate  :thumbsup:
#267 simini22
simini22
  • 23 posts
  • Local Club: SYNT classic car club
Posted 07 March 2015 - 01:56 PM
Great progress mate its gonna be very orange!!!
#268 MrBounce
MrBounce
  • 2,686 posts
Posted 15 March 2015 - 05:32 PM
Ignore this post. Things went wrong...
Edited by MrBounce, 15 March 2015 - 06:04 PM.
#269 simini22
simini22
  • 23 posts
Posted 21 March 2015 - 10:57 PM
Nearly as bright as my GT turbo
#270 MrBounce
MrBounce
  • 2,686 posts
Posted 26 March 2015 - 09:21 PM
But a more manly colour ;D
