Project Zippy - Mk1 1981 Midas Project.
775 replies to this topic
#181 MrBounce
MrBounce
  • 2,643 posts
Posted 11 January 2014 - 03:52 PM
I am a very happy boy. As I had all the necessary bits I thought I may as well drop the crank into the block and leave it there - it was taking up space on the bench after all. So, utilising my Christmas present (cam lube) I smeared the followers liberally and chucked them in their respective holes. I don't have my cam yet (that's coming at the end of the month hopefully) but I may as well install the followers whilst I'm messing around with the block.
Part of my recent Mini Spares delivery included the oil gallery plugs, so in these went as well, with a gentle tap from a 1/4" socket. Then it was time to turn my attention to the crank, the bearing and the main caps. Having made sure everything was scrupulously clean I blasted it through with compressed air (I don't have a compressor so I used one of those cans that IT blokes have), then used plenty of oil on the bearings and pushed them home. Adding loads of engine build lube, I then carefully lowered the crank into place. It fitted beautifully. More lube, and in went the lower thrusts (that's sounds SO wrong...), followed by the middle main cap with the other thrusts attached. Then on with the other two main caps and a shedload of lube. I tightened it up and it was a smooth as you like. I then torqued it up and double checked then crank turned fine. Beautiful!
Followers in, covered in Torco MPZ. Which is VERY messy.
Oil gallery plugs in one end...
...and the other.
Bearings lubed up.
Crank in place and torqued up. 'Tis a thing of beauty.
#182 MrBounce
MrBounce
  • 2,643 posts
Posted 14 January 2014 - 08:49 PM
Back in the Manroom again it was time to fit some pistons. Apart from one small problem. No piston ring compressor. And surprisingly, none of my Mini friends had one, except one. But he wasn't sure where it was, and he happened to be in Wales for a day. I bought one instead.
As the rods and caps were all marked, I was able to carefully clean, then oil, press in the new bearings, lube everything up and then compress the piston rings. Each piston went in with no problems at all (apart from when I tried to put the first one in the wrong way round - beginner's error!), and in what seemed like no time I had four of them smoothly in their bores. Success!
Halfway through...
And 4 pistons snugly in their new home.
Edited by MrBounce, 14 January 2014 - 08:50 PM.
#183 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 16 January 2014 - 12:57 AM
Halfway through...
Nice!
#184 MrBounce
MrBounce
  • 2,643 posts
Posted 25 January 2014 - 04:51 PM
Cheers xrocketengineer!
As I am between jobs on the engine (waiting for funds for the cam amongst other things) I built up the rear brakes. When installing the rear cylinders I found that one of my backplates had the hole for the cylinder locating lug on the wrong side (or was it the cylinder that was wrong??). Out came the drill and a new one on the correct side suddenly appeared. Gaskets went on and then I had the fun job of getting the retaining clips on. I have NEVER been able to do this whilst the backplate was on the car (never had the special tool). However, on the bench it was a cinch. I was able to lever the ends over the cylinder before tapping it down using a socket to get the lugs into the ring. I then put in the adjusters & tappets with plenty of Copperslip. In went the shoes, the springs and the handbrake levers. I tried getting the hubs on, but because I had bought cheap bearings, when torqued up to the correct setting, the hubs would not turn at all. My bad. New ones on order from Mini Spares. I HATE having to re-do jobs.
To keep me busy I dug out the cylinder head and gave it a once over with my Father-in-law Steve's evil degreaser. This made it a fair bit cleaner. I then dried it and gave it its first coat of paint to match the block. Hopefully I will be able to start lapping in the valves soon.
Backplate with locating lug on wrong side. Drill sorted this.
Lovely new brakes with lots of new parts!
Dirty head, ready for a clean.
Not very presentable, but a LOT cleaner.
First coat of paint. Looks SO much nicer!
#185 MrBounce
MrBounce
  • 2,643 posts
Posted 30 January 2014 - 09:58 PM
As I had a few hours' free it was time to get lapping. No, this doesn't mean a jaunt to the local naked ladies' dancing bar, but instead some incredibly tedious work with some grinding paste and some new valves and seats. And as I had everything else that goes with them, I also built up the head.
I have decided that I also don't like my valve spring compressor. It's got a stupidly short handle which means unless you get it at EXACTLY the right angle that it likes working at, it is virtually impossible to use properly. Still, I was eventually able to add the new stem oil seals, compress all the springs, and popped in the colletts with a dab of grease. I am glad I don't have to do that again...
My new wheel bearings arrived so I sorted those (sadly didn't get the chance to use my friend's father-in-law's 15 ton press!) and have popped them on the radius arms. The grease caps are bent and horrible though. Yet more expense...
Valve-less. That soon changed...
Inlets in.
All in and looking good...
...and from the top too.
Hub on. Now need new grease caps. Joy.
#186 blue blood
blue blood
  • 806 posts
Posted 03 February 2014 - 06:11 PM
Great work mate keep it up :)
Regards Blue
#187 MrBounce
MrBounce
  • 2,643 posts
Posted 06 February 2014 - 03:20 PM
Thanks Blue - always good to get encouragement! :thumbsup:
Another couple of hours in the Manroom saw Matt come round with his cone compressor - time to get swearing and fit the doughnuts, Hi-Los, knuckles & top arms. Wasn't too much of a struggle apart from not being able to find both the bolts that go into the captive nuts behind the lockplate. Have left these out for now until I have had more of a chance to look for them. I also appeared to only have one rebound buffer. I KNOW I have two in a bag somewhere... Still, they can be refitted when the car's back on its wheels.
Left side done (almost - bolt missing will be added when I find them!)
And same with the right!
Edited by MrBounce, 06 February 2014 - 03:22 PM.
#188 MrBounce
MrBounce
  • 2,643 posts
Posted 02 March 2014 - 05:28 PM
Well it's been a while since I last wrote anything, mainly due to me doing other non-garage related stuff. I have managed to get a couple of evenings in the Manroom though, mainly consisting of going through the numerous tupperware boxes contained engine bolts, fixtures and fittings which the previous owner had kept from the stripdown. I am not sure how useful old big and main-end bearings are (apart from for locking the flywheel), nor old valves (which looked pretty manky) but I did dig out the pushrods. They unfortunately had been kept between two pieces of gaffa tape, which was at least 5 years old. I didn't much fancy scrubbing these clean; however my friend has a wire-wheel attachment on his bench grinder, so a quick few minutes' work saw them useable again. I will give them a dunk in the parts washer too just to make sure!
I also pulled the cam out from somewhere deep under the bench. This was just a standard low compression Metro A+ unit so not much use to me; I was shocked at how much cams have gone up but this is of course because they now have to be made from new blanks. Gone are the days of buying a Kent cam kit for £60... Luckily for me, Mini Spares do their own flavours and once the £50 exchange was taken into account, £70 odd is much nicer than about £180! I have gone for their Evolution 001 (similar to the Kent 286) which they put into their built 1293 & 1380 engines. That's good enough for me. I did consider the Evolution 002 (similar to the Kent 266) but I have already had an engine with one of those; this will not be an everyday car so I can cope with something a little spikier! Now I will get to play with my new dial gauge when I time it in...
Cleaned pushrods. Gaffa tape is not good for engine internals.
Old cam. Worth £50 to Mini Spares. They now have it...
...because I have one of these!
#189 MrBounce
MrBounce
  • 2,643 posts
Posted 06 March 2014 - 10:07 PM
Well I have managed to get my hands on a timing cover, which is beautifully powder coated in red. So of course it'll need painting as red & orange will look a bit rubbish together. However, as I am fitting Duplex timing gear, I needed to modify it anyway, or the chain will catch and either wear through the cover or wear itself out very quickly, or both. I need to "relieve" a small indentation on the inside, which meant hitting it with a hammer. Everyone knows that this is the best form of engineering as it's so therapeutic. I also had to get rid of the "collar" which sits on the inside of the cover around the breather hole. I used the Dremel for this as it was far easier and slightly less brutal than the angle grinder... I gave it a decent wash in the parts washer afterwards to get rid of all the swarf.
I also needed to modify the engine front plate by countersinking two holes to accommodate the two screws supplied in the Mini Spares Duplex kit. The standard bolts foul on the timing gear otherwise and everything gets messy. I was ready to fit the cam, but the box marked "Engine & gearbox gaskets" mysteriously only had a set for a gearbox. This means I need to go shopping. Again. Whoop-di-doo.
Modified (and soon to be painted) timing cover.
Countersunk holes in engine front plate.
Cam ready to go in.
#190 MrBounce
MrBounce
  • 2,643 posts
Posted 09 March 2014 - 07:47 PM
I hate woodruff keys. There - I've said it. I know they're a major part of timing in an engine but they are a pain.
I lubed up the cam and gently pushed it into place, making sure I didn't bash into anything (especially the bearings) on the way. Then out came the Blue Hylomar and I chucked on the front plate, complete with properly countersunk screw holes. I loctited the screws in place and primed then bolted in the new oil pump. All I needed to do next was to line up the two timing gear wheels using the dot to dot method (lined up with a steel rule) before dropping them onto the shafts with the chain on.
With this project it was easier said than done, mainly because the woodruff key in the camshaft would not stay put. It wasn't particularly loose, it was just that if I was ever so slightly out (we are talking fractions of a millimetre here) the key would either push back and up or back and down. I just could not get the poxy thing right. After an hour of head scratching, lining up and nearly throwing things across the garage, I took a break. A swig of Pepsi Max and a couple a Jaffa Cakes later, it went on as smoothly as the Haynes manual would say ("refitting is the reversal of removal").
Of course, I am now going to check the cam timing properly using a dial gauge so it'll be interesting to see if it needs an offset wodruff key. I can then swear a lot again because I will have to do it all again...
Cam in block.
Front plate one (before oil pump fitted)
Duplex timing gear finally on (at bloomin' last!)
#191 MrBounce
MrBounce
  • 2,643 posts
Posted 16 March 2014 - 12:18 PM
Armed with a dial gauge I swept into the garage feeling confident. Despite not having used one before, they sound very much scarier than they actually are as they're pretty simple to use. I had a useful guide from Andy and additional help from Doug on the Mini Forum and very constructive and valuable it was too. Thanks guys!
I first made sure that everything was perfectly set up at TDC by measuring where the gauge changed direction when number 1 piston reached the top of its stroke. The dots on the timing gear were perfectly lined up. Excellent. Then I popped a pushrod into number 1 inlet hole and took a reading of when it was at maximum lift. This was 107 degrees on the protractor wheel, exactly what the camshaft should be timed in at according to Mini Spares. I then backed up the crank by 0.025" on the dial gauge then brought it forward to 0.005" and made a note of the protractor wheel (100.5 degrees). I then turned the crank forward once again until the gauge went to zero before changing direction again. Once it read 0.005" before zero, I checked the protractor again. This time it read 112.5 degrees. I added these two figures together then divided by 2 to see if I needed an offset woodruff key. As it was 106.5 degrees and the camshaft should be timed in at 107 degrees, I would call that pretty much bang on for my engine spec. A good morning's work!!
I also fished out the timing cover bolts which had been sitting in a box of bolts since the previous owner dismantled the engine. Oh dear. They were covered in grime and dirt. I have left them soaking in some degreaser and will give them a good clean up next time.
Top Dead Centre
Max lift on Number 1 inlet.
Difficult sums.
Oh my. Those bolts are dirty...
#192 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 March 2014 - 02:47 PM
This is really going to come in handy when i re-build my engine. I haven't got a clue what i'm doing!! well as far as timing goes anyway!
Nice work mate
Ben
#193 MrBounce
MrBounce
  • 2,643 posts
Posted 25 March 2014 - 09:35 PM
The Manroom has been in a complete state, plus there were things I needed to do before starting back on the engine. So, after cleaning the place up, I finally found the oil thrower to go on the crank. It was, like the timing cover bolts, utterly filthy, so it spent 3 days in some degreaser. It was much cleaner when I had finished with it.
The timing cover I had bought was powder coated red - not an ideal match for a blue engine block and an (eventually) orange car. So out came the wet and dry and I rubbed it down, primed it and sprayed it silver. Once dry I pushed in a new oil seal and out came the Hylomar to put the new gasket on. The oil thrower was chucked on and the timing gear was given a generous coating of engine oil. The cover has been bolted down nicely and everything looks pretty smart.
I am now having the fun task of cleaning the flywheel housing and wok. They are, of course, disgusting. I also need to clean my gearbox before sending it off the Guessworks for a refurb. I sense a weekend stinking of degreaser coming up. Women like that, right??? :lol:
Primed timing cover.
And the finished article, complete with new gasket, seal & oil thrower in place.
#194 MrBounce
MrBounce
  • 2,643 posts
Posted 30 March 2014 - 03:54 PM
I have been busy. The wok has been stripped down, primed and resprayed in silver. Looking clean (doubt it'll stay that way for too long...). The small problem of seating has been addressed. I was casually browsing ebay and came across a pair of Mk1 MX5 seats from a car that was being broken where the seller hadn't written a brilliant description. The auction also ended at a fairly unusual time (tea-time on a Thursday!) so I chanced my arm and chucked in a cheeky bid - nothing ventured, nothing gained. Nobody else bid on them, so I won them for the princely sum of £20. And they're in really good nick - so much better than others I have seen for sale. It did mean a 1 1/2 hour drive but I like a roadtrip. The guy selling them was a top bloke and they were much better than expected.
I also dragged the gearbox out from under the bench and gave the outside a really good clean. 30 years of road and storage grime is not a pleasant thing to have to get rid of. Still, an hour with the degreaser and toothbrush had it looking quite a lot better than before. I also was able to confirm it had a 3.44 diff by counting the crownwheel & pinion teeth.
I bunged the water pump on as it's been kicking about in the new parts box for a while, then set to modifying the runners on one of the seats as the Midas has a flat floor with none of the humps the MX5 has. It's pretty easy - lop off the front parts of the runners and drill a hole in the flat runner to run some bolts and spacers. At the back, remove the other "bent" bit so the seats will sit nicely. However, I will need father-in-law's pillar drill for this so after hacking the fronts off, I put them to one side.
Finally I have started stripping the carb. It is going to need quite a clean. It has leaves in it...
Clean wok - you could eat your dinner off it!
£20 for these. I am a very happy boy!!
How disgusting is this??!!
Looks a little better now - this was 3/4 of the way through cleaning.
Waterpump in place
Runners off ready to be modified. 12mm bolts - weird!
My carb might need a clean...
Edited by MrBounce, 02 April 2014 - 10:07 PM.
#195 Rocket.
Rocket.
  • 1,441 posts
Posted 30 March 2014 - 04:25 PM
Great project nice work ! :proud:
    Bing (1)
