Oil Change And Oil Filter On A K Reg Mayfair
Posted 01 August 2011 - 03:56 PM
Posted 01 August 2011 - 04:05 PM
Don't put semi synthetic oil in, you're asking for trouble.
There are loads of threads about oil on here, no one seems to agree.
Although I think you'll find the most used oil is 20w50, a nice compromise between the engine and the gearbox (they share the same oil oddly).
The thinner the oil = more chance of burning oil or leaking it
Posted 01 August 2011 - 04:06 PM
Posted 01 August 2011 - 04:42 PM
Posted 01 August 2011 - 05:27 PM
It was designed to run with mineral oil in its lump, so I wouldn't suggest putting synthetic in...
New from the factory they had 10W40 in them alright, but over the (many) years wear has done it's 'magic' so leaks and oilburn are quite common.
So for now a 15W50 or 20W50 mineral or the best choise you can make.
Posted 01 August 2011 - 09:14 PM
Posted 01 August 2011 - 09:16 PM
Posted 01 August 2011 - 11:21 PM
Cheers in advance.
Chap.
Posted 01 August 2011 - 11:35 PM
Posted 02 August 2011 - 11:18 AM
Posted 02 August 2011 - 11:21 AM
I've been advised to use 10w/40 how sure are you that 20w/50 is safe to use?
Because 20w/50 is British Leylands / Austins / Rovers recommended oil for the mini.
Dave
Posted 02 August 2011 - 11:22 AM
Posted 02 August 2011 - 11:33 AM
Rover only recommended 10W/40 because it's suppose to be a little better for the catalytic converter. I'd rather replace/remove the cat then the entire gearbox!
Posted 02 August 2011 - 12:57 PM
Chap.
Posted 02 August 2011 - 01:19 PM
Car is gonna need just under 5 litres... 2 litres is not enough!I bought 2 Litres of 10W/40 from Halfords
Go for the 20/50 classic that Halfords sell...
