Screws For Grille?
Posted 28 July 2011 - 05:19 PM
are they al the same spec and where can i get them?
Posted 28 July 2011 - 05:55 PM
If I remember I used all the same screws but did use stainless for durability and appearance.
Try your local motor factor/halfords/B&Q altho if you want stainless you might be better sizing them first then ordering on net.
Posted 28 July 2011 - 06:01 PM
Posted 28 July 2011 - 06:09 PM
Only thing you tend to find on grill mounts is the holes grow, so sometimes you need to use a bigger screw
Posted 28 July 2011 - 06:12 PM
Posted 28 July 2011 - 06:21 PM
my grille is currently hanging on with about 3 screws! who knows where the others are...
See diagram here:
http://www.somerford...x...=page&id=29
SCREW, grille to body, upper edge of grille - SCREW-SELF TAPPING-SQUARE END-BLACK FINISH No.6 x 1/4''
SCREW, self tapping, finisher and grille to body - SCREW-SELF TAPPING PAN HEAD POZI No.8 x 5/8''
Edited by L400RAS, 28 July 2011 - 06:23 PM.
Posted 28 July 2011 - 07:00 PM
Posted 28 July 2011 - 07:08 PM
Posted 28 July 2011 - 07:53 PM
Posted 28 July 2011 - 08:47 PM
The grille ends can be pop riveted to the grille, so it lifts on and off as one unit. But many people don't bother with this and just trap the grille ends between the grille and the front panel, so that they are just held in place by the grille when it's tightened up.
I'll take some photos of mine when I get a minute, if you are interested?
Posted 28 July 2011 - 10:04 PM
You drill two holes in the front panel (one at either end of the grille) and pass the two bolts through the panel from the back and then put a nut on each (so that you effectively have two long studs poking out of the front panel). Then you drill two corresponding holes in the uprights of the grille, so that you can slide the grille onto the studs, (with the ends of the studs poking through the gaps between the grille slats). Then the grille is held in place by the two large screw on buttons that you tighten finger tight, (with a big thick rubber washer between the buttons and the grille so that you don't crush the slats of the grille when you tighten them up.)
The grille ends can be pop riveted to the grille, so it lifts on and off as one unit. But many people don't bother with this and just trap the grille ends between the grille and the front panel, so that they are just held in place by the grille when it's tightened up.![]()
sounds interesting -photos would be good, it doesn't sound that bad for installing but seeing where holes are required would be good, will need to get diggin in the shed for the rivet gun tho!
Posted 03 August 2011 - 07:10 PM
Ok..... here's some photos then:
Firstly.... The two bolts/studs mounted on the front panel...
The corresponding holes drilled at either end of the grille....
....& in "Close Up"
.....Now with the grill slid into place
.....and with the rubber washers fitted
.... and finally the finshed article.... Simples!!!
....If I were to fit them again I would probably move the bolt nearest the camera more toward the centre of the grille a little, to make them more evenly spaced. I also would'nt have tightened this end up so tightly the first time I fitted them, as you can see I managed to bend/flatten the slats a little by being too heavy handed!!.... But hey "You live and learn" and all that!!
Edited by AVV IT, 03 August 2011 - 07:11 PM.
Posted 03 August 2011 - 07:26 PM
Posted 03 August 2011 - 10:31 PM
Posted 03 August 2011 - 10:35 PM
