Mk2 Saloon, Retro Rebuild, Plumbob.
106 replies to this topic
#91 jagman.2003
jagman.2003
  • 1,307 posts
  • Local Club: Owner of my own club of Minis
Posted 09 August 2015 - 07:36 PM
To undo the pinion nut I tried clamping the gearbox to the bench. But that wasn't feeling very sturdy.
Also the nut seemed very tight as I broke two socket extensions.
So I drilled some holes in a metal frame & bolted it to that. That gave  alot more rigid position to undo the nut.
I'll use this frame again to tighten & for future gearboxes.
#92 jagman.2003
jagman.2003
  • 1,307 posts
Posted 11 August 2015 - 02:46 PM
Gearbox is slowly coming apart.
Only grabbing an hour or so when I can.
It's fairly smooth so far, following the workshop manual.
Still no idea what I'm doing, but hopefully all will become clear!
#93 Daz1968
Daz1968
  • 2,058 posts
Posted 11 August 2015 - 05:01 PM
If you don't mind me asking, which engine paint did you use as the colour looks a lot better than the one I bought
#94 jagman.2003
jagman.2003
  • 1,307 posts
Posted 12 August 2015 - 07:37 AM
Hello Daz,
It was one from eBay several years ago.
This may be the seller? Link
But I can't believe I paid that much?
I agree it's a better shade of green than the Carplan or similar.
#95 jagman.2003
jagman.2003
  • 1,307 posts
Posted 17 August 2015 - 07:28 AM
Got the gearbox stripped down.
Scrubbed the casing inside & out.
Gave it a quick coat of paint before starting rebuild.
#96 jagman.2003
jagman.2003
  • 1,307 posts
Posted 07 March 2016 - 08:15 AM
I haven't stopped working on this project. It's just been very very slow.
I've got the gearbox together. Just attaching the final parts.
Very good customer support from Guessworks.
Hoping to start accelerating this build in spring.
#97 blueovalcraig
blueovalcraig
  • 193 posts
Posted 08 March 2016 - 04:01 PM
Looking forward to seeing the next part  :)
#98 Notay
Notay
  • 153 posts
Posted 09 March 2016 - 07:16 PM
looking forward to see the next post also!
#99 jagman.2003
jagman.2003
  • 1,307 posts
Posted 31 March 2017 - 06:51 PM
Well it's been over a year since the last post. But it has had some work done honest.
The gearbox took some time to get right, but all done now. Had to come apart again several times. made for good practice.
I've done the idler gap, next for the engine & box to join up.
Picture is a bit crap, but best I could get in failing light.
#100 jagman.2003
jagman.2003
  • 1,307 posts
Posted 03 April 2017 - 06:50 PM
Engine & gearbox finally together.
Just need to get the flywheel & transmission together.
Started adding some of the last engine parts too..!
#101 johnR
johnR
  • 2,297 posts
Posted 04 April 2017 - 01:07 PM
looking good
johnR
#102 jagman.2003
jagman.2003
  • 1,307 posts
Posted 05 April 2017 - 11:39 AM
looking good
johnR
Thanks John.
#103 jagman.2003
jagman.2003
  • 1,307 posts
Posted 14 April 2017 - 06:31 PM
I had debating whether to use an alloy, chrome or original green rocker cover.
Inspired by JohnR's rocker cover cleanup, I've gone for the green. More classic look.
After alot of scrubbing I got the original paint off the outside & 50 years of baked on grime from the inside.
So far so good.
Edited by jagman.2003, 14 April 2017 - 06:32 PM.
#104 johnR
johnR
  • 2,297 posts
Posted 14 April 2017 - 09:51 PM
Glad I could be of assistance! I do love a shiny green engine - I painted my last rocker cover satin black but I might go with green on the 1275. keep up the good work.
JohnR%5BIMG%5Dhttp://i76.photobucket.com/albums/j32/johnR21/001_zps1jjzk2hd.jpg
#105 jagman.2003
jagman.2003
  • 1,307 posts
Posted 01 May 2017 - 07:11 PM
I've had a bit of charge on the engine. Just want to get on with this & other projects now.
Engine getting close to being complete.
Flywheel housing & flywheel/clutch on.
I went through four old oil pipes before I gave up & bought a braided hose version. They were all too old & rusty or early type.
Hopefully get this all rounded up this week.
