Re-shelling
37 replies to this topic
#1 cakes
cakes
  • 24 posts
Posted 19 July 2011 - 12:44 PM
could anyone give me information regarding reshelling a mini ??????
#2 Cooperman
  • 23,276 posts
Posted 19 July 2011 - 01:07 PM
What do you want to know? Do you want the legalities or the work involved?
#3 cakes
cakes
  • 24 posts
Posted 19 July 2011 - 01:16 PM
the legalities mate, regarding logbook and vin plates etc !!!!!!!!!!!!
#4 Cooperman
  • 23,276 posts
Posted 19 July 2011 - 01:25 PM
OK. The current law says that if you re-shell a car you must use a brand new shell from the original manufacturer and have a receipt to prove it.
However, if you choose to use a rust-free or fully restored 2nd hand shell, it's best not to talk about it on here, or on anywhere really, then you will probably have no problems.
There is a petition to gov't to allow re-shelling for classic cars which it is hoped will regularise the situation.
The cautionary note must be that if you re-shell with a 2nd hand shell and are found out, then the car will be crushed (at worst).
I hope that answers the question.
It is probably best to re-build the shell if it is rusty with as many new panels are necessary, even using a body jig if necessary.
#5 R1minimagic
R1minimagic
  • 4,660 posts
Posted 19 July 2011 - 01:28 PM
The law seems crazy, you can buy whatever 2nd hand parts you like and that's fine so why not a shell? As long as it is all legit, you have both logbooks and use whichever bits you want then record the other car as scrap, i dont understand!!!
#6 lrostoke
lrostoke
  • 6,923 posts
Posted 19 July 2011 - 01:37 PM
I suppose its to stop cars being stolen and stripped for parts. Just playing devils advocate but how many minis get stripped leaving a perfectly good shell ??
If you have both log books then you probably can do that, You'd just have to use the log book that matches the shell you used.
Edited by lrostoke, 19 July 2011 - 01:39 PM.
#7 R1minimagic
R1minimagic
  • 4,660 posts
Posted 19 July 2011 - 01:39 PM
I know but if it is legitimate then wheres the problem?
#8 cakes
cakes
  • 24 posts
Posted 19 July 2011 - 01:48 PM
so basically i can reshell and use my old logbook and vin plate to put on the newer one, and scrap the new logbook from which im goin to use the new shell ??????????
#9 lrostoke
lrostoke
  • 6,923 posts
Posted 19 July 2011 - 01:54 PM
legally no.
It is daft because you can replace subframes, engines, wheels, interior and the car stays the same car.
But legally the identity of a car is the shell and corrisponding logbook.
WHAT you do is upto you though :o
#10 cakes
cakes
  • 24 posts
Posted 19 July 2011 - 02:02 PM
but isnt the only identification mark on the slam panel under the bonnet, and thats only fixed by 2 rivets ??????
#11 ShoutforJoy
ShoutforJoy
  • 738 posts
  • Local Club: TMF+, Automatic Mini Register
Posted 19 July 2011 - 02:46 PM
It's on the inner wing for later minis and is also stamped onto the scuttle panel for some. But you've just about hit the nail on the head!
There are lots of tax exempt minis out there that appear to have much later shells.
As has already been said you really should keep the correct ID with the shell. If (and it's a fairly big if) you get caught with the wrong ID your car can be crushed.
Also remember you can't just scrap a logbook these days - you need to physically scrap the shell that goes with it and get a certificate of destruction or you'll have to SORN it forever.
#12 R1minimagic
R1minimagic
  • 4,660 posts
Posted 19 July 2011 - 02:54 PM
So if you cut a shell up for spare panels you have to keep sorning a car that doesnt even exist, makes loads of sense that!!
#13 Cooperman
  • 23,276 posts
Posted 19 July 2011 - 03:04 PM
I was given a little tip about having to SORN a non-existant car which has been used as a spares donor vehicle, or 'hangar queen' as we call aircraft used that way. What you do is to send the V5 to the DVLA marked 'Permanently Exported'. It is then removed from the computer. Anyway, that's what I was told by someone who should know.
On later cars the shell number is indeed stamped on the lip of the scuttle panel. But that is the panel which always rusts and most are or will be replaced. I asked my MoT tester friend if I was supposed to get a set of metal stamps and stamp the original number into the new panel and he said not to bother as he only looks at the rivetted-on VIN plate. Says it all really.
#14 R1minimagic
R1minimagic
  • 4,660 posts
Posted 19 July 2011 - 03:12 PM
The older blue v5 documents have a box you can tick in section 16 to say the vehicle has been scrapped or that you have personally broken up the vehicle.
The new red v5 does not have this section anymore!!
#15 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 19 July 2011 - 03:27 PM
It's not rocket science...
The identity, registration, log book or whatever you want to call it is assigned to the vehicle, or chassis. Once the legitimacy of that vehicle or chassis comes into question then the identity is no longer valid, hence the introduction of the "Q" plate many years ago.. essentially a vehicle of undetermined source, bitsa, heinz 57 etc etc...
All VOSA are doing in starting to enforce what has been neglected for many years.
A CoD is now required to scrap a car, to show that it has been disposed of in accordance to environmental regulations...
http://www.environme...tion/31887.aspx
PS. As I buy all my cars as a trader, I don't have to sorn them..
Edited by Guess-Works.com, 19 July 2011 - 03:29 PM.
