Gasket Sealant For Rocker Cover?
15 replies to this topic
#1 the_r_sole
the_r_sole
  • 831 posts
Posted 06 July 2011 - 03:16 PM
got a shiney new rocker cover and cork gasket, is it neccessary/sensible to use some gasket sealant on this when fitting? if so can anyone recommend a decent product?
cheers
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 06 July 2011 - 03:19 PM
no not needed
a bit of grease to help it stick is useful
#3 Ethel
  • 25,922 posts
Posted 06 July 2011 - 03:25 PM
Don't over tighten the cover - see the torque figure.
You could stick the gasket to the cover only to make life easier
#4 Cooperman
  • 23,278 posts
Posted 06 July 2011 - 03:29 PM
I normally use a bit of RTV Silicone sealant to keep the gasket on the cover, but none between gasket and block. That way when I remove the cover the gasket stays in place ready for re-fitting.
#5 the_r_sole
the_r_sole
  • 831 posts
Posted 06 July 2011 - 03:37 PM
cheers folks, i think i'll just bash on later then!
(ethel, newly purchased torque wrench at the ready - nice house clearance last night!)
#6 mike.
mike.
  • 6,176 posts
Posted 06 July 2011 - 03:45 PM
Some rocker covers seem to have real trouble holding a gasket in place once its tightened down. My old one was like this.
My solution was as cooperman says, I used some RTV sealant to essentially glue the gasket in place on the rocker cover, left that to dry and then get the other side a slight smear of hilomar before bolting it on.
#7 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 06 July 2011 - 04:24 PM
Yes I remember the alloy one I had on my last engine had a habit of pushing the gasket in or out every time, bloody nightmare, evo stick is a very good option for the gasket to cover joint.
#8 lionmod_boy
lionmod_boy
  • 72 posts
Posted 06 July 2011 - 04:40 PM
like sai you dont need to use sealent but i tend to use a bit of Loctite 5910 Black Gasket Sealant on most gaskets just to give a helping hand and that bit extra seal. is really good stuff and not too dear
#9 MRA
MRA
  • 7,607 posts
Posted 06 July 2011 - 07:37 PM
If its an alloy one I just milled a groove all the way around and use a large O ring cut & glued, never leaks, no need for sealant, and reuseable time and time again... ;)
#10 1984mini25
1984mini25
  • 8,784 posts
Posted 06 July 2011 - 09:04 PM
Spay glue also works and comes away cleanly in the future if when you need to change the gasket.
#11 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 06 July 2011 - 09:08 PM
You should sell them I would be interested
#12 mike.
mike.
  • 6,176 posts
Posted 07 July 2011 - 01:16 AM
That does sound like a very good idea! Maybe offer it as a machining service?
#13 Ethel
  • 25,922 posts
Posted 07 July 2011 - 01:48 AM
The rocker cover torque is only something like 2ft/lb (finger tight), most get overtightened which is why they don't stay put.
Don't you lose a lot of rocker clearance height, Martin?
I had thought of drilling the cover edge to take pins that'd stick in the cork.
#14 MRA
MRA
  • 7,607 posts
Posted 07 July 2011 - 02:13 AM
Yes Ethel you have spotted the flaw, it doesn't work with all variants unfortunately..... that is 1 reason why I haven't pushed out in to the market place, the other is its a ball ache to set up... especially with all the variants and the range of quality..
Also depends on the camshaft used as well..
It does however work with my DSC Windsor roller set ;)
#15 mini_matt_106
mini_matt_106
  • 591 posts
Posted 25 July 2011 - 12:05 AM
You could machine a matal spacer to replace the cork?
