Ball Joint Splitter
9 replies to this topic
#1 Tommyboy12
Tommyboy12
  • 2,254 posts
Posted 05 July 2011 - 11:27 AM
Hi guys. Just a quick one. Which type of splitter is best?
Forks are obviously the cheapest but a cup looks better. Scissor type seems supreme but the price is high. I want to reuse the ball joints its the wheel bearing thats knackered!
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 05 July 2011 - 11:33 AM
I like the scissor type, not that expensive ?? about £10
http://www.machinema...l-joint-remover
Halfords seem a bit pricey, £22 for same thing
http://www.halfords....tegoryId_165727
#3 jbj
jbj
  • 190 posts
Posted 05 July 2011 - 11:35 AM
I use the fork type and have had no problems with it (mainly due to being a fan of the brute force type approach).
#4 Tommyboy12
Tommyboy12
  • 2,254 posts
Posted 05 July 2011 - 11:42 AM
Is there a risk of damaging the ball joint with a fork though?
#5 Cooperman
  • 23,283 posts
Posted 05 July 2011 - 11:48 AM
The fork-type seems to damage the rubber cap, but it shouldn't harm the ball joint itself.
The scissor-type is best.
#6 typer andy
typer andy
  • 79 posts
  • Local Club: Kings Lynn Mini Club
Posted 05 July 2011 - 11:53 AM
i wont be using a fork type ever again. they bend open damage components around it and never seem to work as they should.
id say the scissor type would be my next port of call
Edited by typer andy, 05 July 2011 - 11:53 AM.
#7 racingbob
racingbob
  • 3,061 posts
Posted 05 July 2011 - 12:14 PM
[quote name='Tommyboy12' date='Jul 5 2011, 12:27 PM' post='2168238']
i just bought sisscor ( how the hell you spell sisscor ) type it work fine all of a sudden bang off it drops, got it off ebay only about 10 quid with post
I USED TO HAVE A WEDGE TYPE ONE WHEN RACED MINIS YEARS AGO AND YES IT CAN DAMAGE THE RUBBER CUP
#8 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,034 posts
  • Name: Neil
Posted 05 July 2011 - 12:37 PM
They both have their plus's and minuses, if the joint is really stubborn you can strip the threads in the scissor type (been there need to replace mine) and so the fork one comes into its own there.
I have also tried the technique of hitting either side of the joint with two hammers at the same time (saw it on wheeler dealers and gave it a try) although the joint did not spring apart the shock did loosen it so a light tap on the nut did spring it apart (do not hit the thread you will damage it, always leave the nut on with enough threads engaged.)
I would rather use the scissor type at the end of the day especially if you are reusing the ball joint / track rod end etc.
#9 james962
james962
  • 2,677 posts
Posted 05 July 2011 - 12:44 PM
Scissor type everytime :thumbsup:
#10 Tommyboy12
Tommyboy12
  • 2,254 posts
Posted 05 July 2011 - 04:19 PM
Bought the scissor type. Came off no problem. Wheel bearing changed and back together. All good! Now I need to get my manifold welded up and then I can get it through an MOT! Thanks for the help guys.
