Lose Of Oil In A Day But No Leaks?
Posted 04 July 2011 - 08:52 PM
yesterday night my car over heated steam everywhere, have now sorted it. but what i have found since having the car especially yesterday, i topped up my oil that morning then checked it next day and was on the minimum line again??? really need help.
its is a 1986 leaded austin mini
Posted 04 July 2011 - 09:04 PM
If you're absolutely sure it's not leaking out, it must be consuming it. Does the engine smoke, particularly blue in colour? Are there oily deposits around the exhaust pipe?
Posted 04 July 2011 - 09:06 PM
blue smoke means burning oil.
Edited by maggies_minder, 04 July 2011 - 09:07 PM.
Posted 04 July 2011 - 09:07 PM
Posted 04 July 2011 - 09:08 PM
really don't know what that mean/ what should i do??
why would it burn the oil is what i need to know
cheers guys
Edited by cliffordliam, 04 July 2011 - 09:09 PM.
Posted 04 July 2011 - 09:11 PM
Keep the oil at the minimum mark. This will limit its usage but check it every day.
What grade oil are you using?
Posted 04 July 2011 - 09:15 PM
how much would you reckon to get it all sorted if the piston rings/ bore are worn??
cheers
Posted 04 July 2011 - 09:20 PM
Oil consumption is not a problem in itself, it doesn't normally signify an engine that is about to dramatically explode, especially if it has been like this a while, which I'd imagine it has. It just means its had its day and requires a rebuild.
Don't use 10w 40, even though that's what the later manuals suggest. Use a good 20w50, I use the Halfords Classic stuff. Change to the 'thicker' oil and you may even find the usage drops.
Does the engine 'breathe' through the oil filler cap if you remove while its idling?
Posted 05 July 2011 - 10:38 AM
Posted 05 July 2011 - 10:48 AM
check all the gaskets might be something simple such as you say the head gasket just needing replacing
