Quick Release Steering Wheel
12 replies to this topic
#1 A362 TTU
A362 TTU
  • 525 posts
Posted 03 July 2011 - 08:44 AM
Model: Sprite
Year: 1983
Basically i want to go quick release on my steering wheel. i currently have a non-standard wheel, but i believe the bolting pattern is standard,
Its the same pattern as this wheel:
So what parts will i need?
i would like to keep the wheel as far away from me as possible as i am on the taller side - so low profile parts would be better. I would also like to keep costs low (without destroying the quality)
Thanks in advance
#2 drewsargent1980
drewsargent1980
  • 377 posts
  • Local Club: Anglian Mini Club ( AMC )
Posted 03 July 2011 - 08:52 AM
I got this for my Mountney Wheel. Which is the same as the one you have pictured above. all that is also needed is the exsisting Boss.
http://www.minispare...mp;prod_id=2703
Edited by drewsargent1980, 03 July 2011 - 08:56 AM.
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
There are a few different bolt patterns for wheel boss', to say any of them is standard would be stretching it a bit. Most companies use their own pattern.
You need a quick release boss for a Mountney wheel with a Mini spline. I'm not sure there are any low profile Q/R bosses that use the Mountney pattern, it's quite old now and most newer designs are different.
#4 A362 TTU
A362 TTU
  • 525 posts
Posted 03 July 2011 - 08:59 AM
Thanks. i also have a MOMO 3 bolt (triangle pattern) wheel that i could use.
So do i just order the boss and then im ready to go?
EDIT: googling mini spline to mountney wheel dosnt bring anything back useful, same as if i do for momo
Edited by howgudami, 03 July 2011 - 09:09 AM.
#5 A362 TTU
A362 TTU
  • 525 posts
Posted 04 July 2011 - 02:51 PM
BUMP.
Think i will go with my MOMO wheel.
it has a triangular bolt pattern (3 bolts) -
Any ideas on what i need to get it on?
Thanks. :D
#6 A362 TTU
A362 TTU
  • 525 posts
Posted 04 July 2011 - 05:09 PM
Anybody?
Is this thread in the wrong section or something?
#7 minilester
minilester
  • 770 posts
Posted 04 July 2011 - 05:11 PM
i'd like to know alot of this as i want a snap off wheel but have no idea where to start and i have nothing to start with.. anyone make me a "shopping list" please...
whoops!.. slight high-jack.. sorry fella...
Edited by minilester, 04 July 2011 - 05:12 PM.
#8 A362 TTU
A362 TTU
  • 525 posts
Posted 04 July 2011 - 05:31 PM
no thats fine :)
Thats what im after too.
here is my wheel i can use: (im hoping the pic will help people help me)
If the spacing is the same as the usual modern 6 point wheels (is it?) could i use this boss? and just use 3 screws.
http://www.ebay.co.u...6#ht_2953wt_901
or even this:
mentioned earlier
any help would be awesome :D
Edited by howgudami, 04 July 2011 - 05:33 PM.
#9 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 04 July 2011 - 05:37 PM
The wheel at the top is a Mountney classic and i am not aware fo any off the shelf 'snap off' boss kit that will fit it.
The Mountney sport wheels have a smaller more common and standard bolt pattern that will fit the most common and available snap off boss kits. :D
Im not so sure about the Momo wheel
#10 A362 TTU
A362 TTU
  • 525 posts
Posted 04 July 2011 - 06:19 PM
Thanks, im wondering if the Momo wheel is effectively 3 of the 6 bolts that the mountney sport wheels have.
It is an odd pattern though
#11 adpenman2301
adpenman2301
    Just On Tickover
  • 5 posts
Posted 05 November 2011 - 07:07 PM
Same problem, think I've found solution - a new boss unit - pretty much same length as standard boss unit
https://www.europasp...___144444_.html
#12 majorj0nny
majorj0nny
  • 176 posts
Posted 02 June 2012 - 10:36 PM
i have a quick release kit on a mrk2 golf I had years ago, it was great! and I really want to get something similar setup on the mini now.
its very confusing shopping for this stuff online, when I bought the kit years ago I got it from halfords, which was good cause you could pick the wheel you liked the feel off from the large collection they had in store, get a boss that fitted - then ordered in the quick release kit.
the only 'issue' I noticed was that the wheel ended up (after boss and quick release boss ontop of that) sticking much further out from the position of the original wheel.
you do get used to this is has to be said - BUT, if there was a way to minimize this added wheel height it would be good.
Ive seen slim quick release kits available .. but dont know if they fit mini boss' ?
why dont someone create a wheel that has an inbuild quick release boss ??
so for example I need -
http://www.minispare...id=34839&title=
http://www.minispare...ty=pb&pid=33717
And
http://www.minispare...ty=pb&pid=32750
#13 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 03 June 2012 - 03:16 PM
I feel your pain but keep in mind that a company that makes aftermarket wheels doesn't necessarily want to limit the use of those wheels to one or two makes and models of car nor do they want to limit the sale of those wheels to someone who wants to use a quick release.
I have not seen any high-quality low-profile quick release hubs but most I have seen have been Chinese made. The better quality (taller) spline or hex drive types can be made to work with "street car" steering columns but often require welding in place. That leaves them low-profile but also a permanent addition to the car as you cannot "un-weld" the adapter from the column.
Though not an option for everyone, I have seen off the shelf hubs machined "shorter" and further machined to accept the fixed portion of the quick release. In many cases this completely eliminates the possibility of using the traditional horn button but it is low-profile. This isn't possible with all adapter hubs though as many modern ones are made from expanded sheet metal to achieve a crush zone for accident safety. Older hubs were often die cast aluminum that could be modified.
In summary, anything is possible with the some creativity and money.
