Sand Blast And Powdercoating
11 replies to this topic
#1 liam1288
liam1288
  • 602 posts
Posted 23 June 2011 - 03:37 PM
hi guys, has anyone got any ideas how much it would be to sandblast and powdercoat a set of 12inch minilites...is it possible to diy the sandblasting with paint stripper and sandpaper? make it a little cheaper...or just diy the whole thing yourself?
any advise welcome
thanks
#2 icedaddyuk
icedaddyuk
  • 364 posts
Posted 23 June 2011 - 03:38 PM
any advise welcome
thanks
£50/wheel seems to be the average rate for stripping and painting.
#3 liam1288
liam1288
  • 602 posts
Posted 23 June 2011 - 03:41 PM
is any of it possible to do yourself?
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 23 June 2011 - 03:48 PM
With wheels you sometimes find that they were powder coated from manufacture and its a sod to get off. A decent sand blaster will remove all of it, the same with any paint. The surface has to be totally clean plus if you over use any abrasives it will show through.
Also with wheels if there is any kerbing damage this will need to be sorted or it will show through. Powder coating is not that thick so the surface does need to be a smooth as possible.
Also the powder coaters may not accept the wheels if you strip them yourself as the finish may not be good enough. If you pay them to do the whole job then its down to them for any issues that may or may not occur.
We had a rear subframe plus a load of other suspension components blasted and powder coated for £90. Shop around
#5 Boycie
Boycie
  • 1,978 posts
Posted 23 June 2011 - 03:59 PM
I have many parts blasted, it's the only way to remove the grot completely.
I pay between £7-10 a wheel, which leaves them like new. I don't ever have anything powdercoated, it's a great idea in theory but the risk of cracking/peeling and then letting moisture in is too great IMO.
Tegra Engineering do my blasting, although they're in deepest darkest Kent (Pluckley) and too out of the way for most people!
#6 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 23 June 2011 - 04:14 PM
my local place charges £40 a wheel
i did sort out a TMF discount at a wheel refurb place for TMF plus but it seems to be missed off the list, a member of the admin team might be able to find it for you
#7 liam1288
liam1288
  • 602 posts
Posted 23 June 2011 - 04:15 PM
you just have them blasted so they are just plain?? dont quite understand
#8 Boycie
Boycie
  • 1,978 posts
Posted 23 June 2011 - 04:20 PM
Yes, they come back in their natural metal state, with a nicely keyed surface ready for primer. Alloys can stay like that for ages until you're ready for paint but steel parts can 'flash rust' in a matter of hours if left in a damp area.
I etch prime mine straight away and leave them in the house unless it's the middle of summer!
#9 liam1288
liam1288
  • 602 posts
Posted 23 June 2011 - 05:34 PM
im wanting to sell them after but im just wondering if it would be worth it at 40-50quid a wheel...i probably wouldnt get my money back...
#10 grayclassic
grayclassic
  • 23 posts
Posted 23 June 2011 - 08:37 PM
any advise welcome
thanks
#11 minikidx14
minikidx14
  • 1,387 posts
  • Name: Ross
Posted 26 June 2011 - 11:17 AM
I can do them for £30 each :)
#12 liam1288
liam1288
  • 602 posts
Posted 26 June 2011 - 12:42 PM
yeah i saw your message about you being able to do it but figured your a bit too far from bradford... lol
