That diagrams does show it with the feed from the Main Beam circuit to the switch. That circuit will also flash the driving lights with the Main beam flash as long as the switch is on.
Main beam wiring is blue/white.
Surely if the switch is on then the lights would be on anyway. I want to be able to flash them from off
This was posted on a previous topic on this and shows the relay being triggered by the steering stalk flash but there is no switch facility to bring the spotlamps on seperately so their on permanently, only the fogs have a switch
yes it was also mentioned to take the supply from the starter (battery supply) not overloading the fusebox as they've done above
