3 Pin Switch-why Does It Have The Earth?
Posted 21 June 2011 - 11:54 AM
This is the link
http://www.halfords....nstructions.pdf
I'm in the middle of doing my wiring so found this useful,
I have already bought a few two terminal switches (on/off) but in this diagram they have three terminal switches with one being an earth, why have they included an earth on the switch is this really necessary, I cant see any reason why it would be needed my switches are plastic rocker type??
Posted 21 June 2011 - 11:59 AM
Just read the part list at top of page
An illuminated rocker switch (optional for driving lamps)
Edited by lrostoke, 21 June 2011 - 12:00 PM.
Posted 21 June 2011 - 12:09 PM
Posted 21 June 2011 - 12:16 PM
if your fitting fog lights you must have some sort of light to tell you they are on
Is this a legality or something you think I would need to save me getting stopped if I mistakenly put them on
Posted 21 June 2011 - 12:18 PM
If its a fog light switch they have probably shown a switch with built in warning light. So needs an earth to illuminate the light
Thanks, that makes sense now, the earth is for the filament
Posted 21 June 2011 - 01:19 PM
Really? All that extra light in front of the car isn't enough indication? No reason to even turn them on during daylight hours.
Posted 21 June 2011 - 01:23 PM
Posted 21 June 2011 - 01:35 PM
If the rear fog is for "backing up", surely it would be wired in parallel to the reverse light and should not have its own switch. If the rear fog light has its own switch, it sounds like it's more of a weapon against people following too close at night.
Posted 21 June 2011 - 01:39 PM
I think the boot mounted reverse light is what you are thinking of, guess thats more a style thing these days but probably came about when there wasn't a reversing light fitted
Used to have one on my Landrover mounted on top of body but shining down so it lit up the road just behind me, was pretty useful
Edited by lrostoke, 21 June 2011 - 01:42 PM.
Posted 21 June 2011 - 02:13 PM
Am I right in thinking this diagram only allows for the manual switching on of the lamps via the switch. How do I add in the facility for the driving lamps to flash with full beam.
Also does anyone know what colour the headlamp main beam circuit wire is I've followed the haynes diagram and think its red/green but this colour is also used on alot of the other lighting cct's
Posted 21 June 2011 - 02:35 PM
i can tell you don't do much driving in the UK Doug
if your under the age of 20 and drive a saxo/106 etc and it looks like it's crashed through the ripspeed section of halfords then you must drive around with your fog lights on no matter what the weather of time of day
Posted 21 June 2011 - 02:40 PM
there are many topics on this already on TMF how you didn't manage to find them is beyond me
are you fitting fog or spot lights ?
as the lights are to be used for different things and must be wired differently
Posted 21 June 2011 - 02:57 PM
Main beam wiring is blue/white.
Posted 21 June 2011 - 03:48 PM
It must be beyond you Bungle as I did search, thats where I initially got the link from.
I'm fitting 4 spots, 2 fog and 2 normal. I'am aware they are 2 differant circuits but both have the switch wired the same. It is only the headlight/driving lamps I'm concerned with when operating full beam.
There are loads of topics on this subject but none ever seem to get a completed answer as people always say use the search feature.
The search feature is'nt all that good unless you use the advanced search and search by title, it should be set to default so the search by title box is ticked rather than whole posts then people would find what they're looking for easier without getting a thousand irrelevant topics.
I also find its easier to search via google then all the forum's topic titles come up sorted by relevance if you put in the correct key word
Posted 21 June 2011 - 04:20 PM
Very true. I haven't even been to the U.K. in over 20 years. It sounds like your youths outfit and drive their rice-racers about the same as kids over here.
Steve, thanks for clarifying the rear light thing. You are right that I was thinking of the rear lamp on the boot lid.
Back on topic.
