1986
When my car was resprayed, the guy who did the work simply took all the parts off the car, and rather than disconnecting them - Just cut the wires going to everything. This has been done for the headlights, sidelights, indicators, horn - Maybe more bits that i've not thought of yet. But at the moment i'm left with quite a lot of loose ends and I need to track it all down and get some labels on these wires so I know what to connect to them.
I've been studying the haynes wiring diagrams to try and track which colour wires go to which components, but its not been a massive help as I never know which of the diagrams applies to my car and it doesn't show very well which way round the wires connect to some of the components.
Below is what i've got from the haynes diagram, just wondering if anybody could check it or knows off the top of their head if this is right before I start wiring things wrong.
Headlights - Same wiring for RH/LH and the colours are:
Blue/White
Blue/Red
Black
I'm pretty sure i've got that right - However which wire connects to which connection on the bulb? I'm going to be wiring in these replacement H4 plugs: Link
So as if looking at the back of the bulb they have yellow coming off the top pin, blue coming off the right hand pin and pink coming off the left hand pin - So which colour wires from the cars loom connects to which of the wires on the plug?
Indicators
RH wires are one Green/White and one Black
LH wires are one Green/Red and one Black
Is that correct?
Horn
Haynes says the horn connections are one Purple and one Purple/Black - I'm not sure about this, I had a quick look at the wires hanging around the grill area and can't see these wires. I've either not looked hard enough or i've got the colours wrong from the haynes
Those are the main components I need to wire back in, however i've also got quite a few other wires coming out of the loom in the grill area which I don't know what to do with. Below are a few pics if anybody can help me identify what these wires connect to.
I know the black and white ones are coil connections - But i'm running megajolt so I just need to insulate those and leave them be - However theres 3 of them?
But then theres a White/Brown wire with a spade connection on the end - I though this connected to the oil pressure warning switch but the wire isn't long enough so can't be that?
Then theres a White/Orange and a Yellow/White which I don't know what they're for?
Then theres the third Black/White wire with a spade connection on it, this is quite a short wire?
A White/Yellow wire with a spade on the end - You can see theres an unused spade connection on the starter which it looks like it goes to but my car starts without this wire connected so what does it do?
Finally there a Green/Blue wire coiled up and taped there aswell
Can anybody name these connections?
