Stinky, The 1979 Clubby Estate
184 replies to this topic
#121 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,135 posts
  • Name: Sean
Posted 26 January 2012 - 09:44 PM
I'm heading down on Saturday afternoon!!
Hardcore baby!!
#122 minimuk
minimuk
  • 1,946 posts
Posted 26 January 2012 - 09:46 PM
good luck, see you on Sunday perhaps, any hint's where to park appart from being there about 9?
#123 Shifty
Shifty
  • 13,135 posts
  • Name: Sean
Posted 26 January 2012 - 09:49 PM
There's usually a big car park leading up to bingley!! Either get there early or late, only way to avoid the queues!1
#124 minimuk
minimuk
  • 1,946 posts
Posted 26 January 2012 - 09:53 PM
so 9ish should be good, pending on snow drifts,........
#125 Shifty
Shifty
  • 13,135 posts
  • Name: Sean
Posted 26 January 2012 - 09:58 PM
Last time I went, it was so cold I had ice in the footwell of my Elf!!
#126 minimuk
minimuk
  • 1,946 posts
Posted 26 January 2012 - 10:16 PM
was rather cold last year, survival kit needs packing,.....
#127 Shifty
Shifty
  • 13,135 posts
  • Name: Sean
Posted 27 January 2012 - 03:54 PM
Quick update....
Stinky Runs!!!!
That's all for now!
#128 Shifty
Shifty
  • 13,135 posts
  • Name: Sean
Posted 27 January 2012 - 08:11 PM
Today has been a goood day!!
Did all that I needed to(and more)
Stinky now runs, moves, brakes.
Engine in
Front suspension completed
Rear suspension bits..
And on the car..
Finally, back on his wheels..
Had a few snags, a terminal snapped off the starter solenoid and had to get a new one.
Also the alternator is now noisy, despite it being fine when i removed it(go figure!!). Its still charging and I'll get one at the show.
Plan for tomorrow..
Set ride height.
Set tracking..
Sort seats.
Buy beer!!!!
See you at Bingley!!
#129 minimuk
minimuk
  • 1,946 posts
Posted 27 January 2012 - 11:22 PM
Excellent, ready to roll tmr afternoon by the looks of it,.....I do like when plans come toghether,.........however.....................
I am not so sure if it get mine rolling,....I have got a few serious ignition wiring isseues to deal with tmr, juddering and loosing power over 4000refs,, can't get passed 50mph in 4.
Fueling, timing, coil, points condensor, all good, feed of +14V from solinoid via ignition switch going in dizzy , idle (1000rpm) pulls 6V to condensor and points, when increasing revs starts to judder over 4000rpm feels like don't get enough power trough wires, spark between in points getting weaker in strenght. so there must be a leak somewhere,......
Edited by minimuk, 27 January 2012 - 11:24 PM.
#130 Shifty
Shifty
  • 13,135 posts
  • Name: Sean
Posted 27 January 2012 - 11:23 PM
If you come to the show in him I'll take a look at it with you!!
#131 Shifty
Shifty
  • 13,135 posts
  • Name: Sean
Posted 27 January 2012 - 11:24 PM
If theres a leak in the inlet, you can check using wd40!!
Let the engine idle and spray wd40 arounf the inlet manifold, if the revs pick up then its sucking the wd40 into the engine!!
#132 minimuk
minimuk
  • 1,946 posts
Posted 27 January 2012 - 11:33 PM
Cheers, I have replaced the earth wire in the old dizzy tnight(old one was f++++k), and that do make a little change for the better,
I will have a go with the wd40 that would be an easyer 'repair' with a few new gaskets, when driving today I have pulled out the chocke a bit when juddering was happening, and that did get rid of the juddering, but I do know the carb is set perfectly and so is the timing, valves are all set at 12/13 thou,...the whole situation is just bloody annoying
#133 Shifty
Shifty
  • 13,135 posts
  • Name: Sean
Posted 27 January 2012 - 11:42 PM
What oil do you have in the dash pot?
#134 minimuk
minimuk
  • 1,946 posts
Posted 27 January 2012 - 11:45 PM
yep, using 3in1
#135 Shifty
Shifty
  • 13,135 posts
  • Name: Sean
Posted 27 January 2012 - 11:46 PM
Try a thicker oil, the thicker it is the richer it will run under acceleration. Stick some engine oil in a try that.
