Stinky, The 1979 Clubby Estate
184 replies to this topic
#91 minimuk
minimuk
  • 1,947 posts
Posted 07 January 2012 - 11:48 PM
That could be a bit tricky as its probably a taper thread?
Equally, you don't want to be risking bits of metal dust going in the engine.
How overtightened was it? Could you do it with a good quality easy out?
I've used left handed taps for that kind of job in the past with good sucess.
I have used the left hand taps but it aint shifting, so yes tight indeedy, I know what you mean with the metal bits in the engine, thinking of hoover nozzle next to it and dremmel on low speed,.....
#92 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,157 posts
  • Name: Sean
Posted 07 January 2012 - 11:51 PM
If you've tapped it out left handed then you could use a left handed bolt to unscrew it?
Heat up the area around it with torch to help it as well.
#93 minimuk
minimuk
  • 1,947 posts
Posted 07 January 2012 - 11:56 PM
will heat it up tmr with torch, and try not to put car alight and find a left handed bolt,......Halfords? B&Q?
#94 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Posted 08 January 2012 - 12:00 AM
Bleeding hell on a sunday you're gonna struggle?
Halfords would be the best bet but I wouldn't be holding my breath!!
#95 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Posted 08 January 2012 - 12:02 AM
Maybe charlies or telford farm machinery on the Rabbit run?
#96 minimuk
minimuk
  • 1,947 posts
anywhere on a mini a left-handed bolt, still got the other one to do, otherwise it will be Monday, there is a place in Monkmore
#97 minimuk
minimuk
  • 1,947 posts
Posted 08 January 2012 - 12:05 AM
Charlies could be good. my side of town,...will try tmr will let you know how it went,....if it does!
Edited by minimuk, 08 January 2012 - 12:06 AM.
#98 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Posted 08 January 2012 - 12:06 AM
I haven't got anything here either.
Good luck anyway.
#99 minimuk
minimuk
  • 1,947 posts
Posted 08 January 2012 - 12:08 AM
Good luck anyway.
Cheers Shifty, sorry to hyjack your tread
#100 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Posted 08 January 2012 - 12:10 AM
No probs, i'd do it to you!!!
#101 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Posted 08 January 2012 - 06:02 PM
Had free afternon so I stuck him back in the garage an got to work.
Fitted the new rack and then some new rear subby mounts. Rather worrying was the loose tower bolts!!!
Another step closer to Bingley!!!
#102 minimuk
minimuk
  • 1,947 posts
Posted 08 January 2012 - 08:08 PM
nice bitta progress there,....all new bits......could do with a bitta paint to I guess....
I had no luck with heat on bit in engine, so tmr going for set of bolt extractors. give that a go if all fails.......next move
#103 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Posted 08 January 2012 - 08:19 PM
Make sure you use a good quality one, if you snap one off then its game over!!
#104 minimuk
minimuk
  • 1,947 posts
Posted 08 January 2012 - 08:32 PM
understood, game over----engine overhaul again----
#105 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Posted 08 January 2012 - 08:36 PM
The engine would have to come out for it to go in a milling machine to remove the 'easy out'
Stay away from these..
http://www.ebay.co.u...#ht_4170wt_1037
These look good..
http://www.frost.co....drill-outs.html
