Stinky, The 1979 Clubby Estate
184 replies to this topic
#31 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,142 posts
  • Name: Sean
Posted 16 July 2011 - 07:17 PM
Good grief, its a ghost!!
Nice to see you around SFM!
#32 Tommyboy12
Tommyboy12
  • 2,254 posts
Posted 16 July 2011 - 07:19 PM
Looking good. Speaking of MITP Shifty. Any idea when/who is organising the stand this year?
#33 Shifty
Shifty
  • 13,142 posts
  • Name: Sean
Posted 16 July 2011 - 07:21 PM
I'll have a look and get back to you. If theres not one then I'll get it sorted ASAP.
#34 Tommyboy12
Tommyboy12
  • 2,254 posts
Posted 16 July 2011 - 07:22 PM
Cheers :D
#35 TDOD
TDOD
  • 50 posts
Posted 17 July 2011 - 08:14 AM
You dont mess about with the welder do you, are you respraying the whole car or touching in the bits you have welded?
#36 Shifty
Shifty
  • 13,142 posts
  • Name: Sean
Posted 17 July 2011 - 09:18 AM
I'm kinda running out of time a bit now, I was going to just repaint the drivers side and then touch in the bits on the passengers side. At the mo its looking like a rattle can job at best and more likely primer!!
Really just depends on the time I've got left.
#37 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 17 July 2011 - 10:49 AM
well its looking good anywho
did you sell sudnick in the end ??
#38 Shifty
Shifty
  • 13,142 posts
  • Name: Sean
Posted 23 July 2011 - 09:25 PM
SFM - That one went ages ago(been a few since then as well)
No pics as I forgot to take the camera in the garage.
Had a few hrs today so..
Fitted the refurbed hub to the drivers side front, also noticed that the brake hose was cracked to had to do that as well(luckily had one in stock)
Refurbed the rear brakes.
Seam sealed and then went mad with the shutz gun, everything under the car is now covered in the stuff!!
Finally, removed the head so it can be sent away for an unleaded conversion and refurb, The cylinder bores are perfect, no lip or wear, the 60k on the clock ma be genuine??
Next Saturday I've got a full day so I plan on getting it pretty much done.
Fit head
Service, new water hoses/water pump/radiator and so on.
Refit fuel tank
Check the electrics
Fit new slave cylinder
Fit new engine mounts and stabilser bushes.
Repair A-panel
Fit new exhaust mounts
Bleed brakes and clutch
Once thats done it just leaves the interior to be fitted and then an MOT.
If theres time I'll have a tinker with the bodywork but its not a priority.
I may yet make MITP!!
#39 Shifty
Shifty
  • 13,142 posts
  • Name: Sean
Posted 30 July 2011 - 09:14 PM
MITP is coming up very quickly and I've hit a snag!!
I sent the head off to be overhauled and then converted to unleaded, turns out my head is cracked and therefore scrap...........DOH!!
A few calls later and I got a 2nd hand one off Jason at classic mini bits, life saver!!
Will be taking that one on Monday to be overhauled.
In the meantime I've..
- Fitted new engine mounts
-Fitted new stabilser bushes
-Fitted new water pump and slave cylinder.
Repaired the bottom of the A-panel
Also refitted the fuel tank, what an awful job that was!
Checked out and tested all the electrics, fitted a new number plate lamp.
Still a long way to got, but am getting there.
#40 Shifty
Shifty
  • 13,142 posts
  • Name: Sean
Posted 31 July 2011 - 09:36 PM
Hmm, less than 2 weeks to go and he's still in bits!!
Jobs to do..
- Get new head refurbed and then fit
-Bleed brakes and clutch
-Fit new rad and hoses
-fit interior
-MOT
-Fit stereo
Actually thats not a bad list really, Heads going to be done on Monday and will get it back in a couple of days.
I'm gonna aim for an MOT next Monday, wish me luck!!
#41 izzy
izzy
  • 190 posts
Posted 01 August 2011 - 10:41 AM
looking good keep up the good work
#42 Shifty
Shifty
  • 13,142 posts
  • Name: Sean
Posted 07 August 2011 - 08:36 PM
Well what a weekend I've had!!
Bleeding brakes(literally!!)
Been trying to get brakes on him and had no success, bit the bullet and ordered a new master cylinder from the local factors. Looked ok till I got it home and found it was totally different!!
Arse, this was at 1pm on a Saturday, jumped in the car and just made min-its, bought a new master and a compensator valve as well.
Fitted both and then bled the brakes.....................still no brakes, even after 3 different bleeders used.
The only part of the brakes I hadn't replaced was the passengers side flexy, that couldn't have collapsed and then blocked...........could it?? It looked pretty new.
Guess what?? It was blocked!!
Arse!!
Couldn't get one today so the MOT tomorrow isn't happening.
#43 minimuk
minimuk
  • 1,946 posts
Posted 07 August 2011 - 09:32 PM
bad luck there Shifty,...bet you are peeved-off about MOT, but more about the time and money spend this weekend trying to sort it.
#44 Shifty
Shifty
  • 13,142 posts
  • Name: Sean
Posted 07 August 2011 - 09:36 PM
My engine bay is so full of new stuff its unbelievable!!
Will re book the ticket for Wednesday now, its gonna be tight for MITP at this rate!!!
#45 Shifty
Shifty
  • 13,142 posts
  • Name: Sean
Posted 10 August 2011 - 09:51 PM
Again no pictures and I think I'll keep him under wraps till the MITP debut!
But............
He has an MOT!! Passed today with no advisories.
Drives nicely, did have an annoying rattle but that was cured by bending the front bumper. The brakes could do with another bleed and the drivers side rear wheel bearing is a bit noisy. Apart from that its all good, engine runs nice and strong, no overheating.
All I need to do is give the brakes one last quick bleed, fit the stereo and its all good!!
Woo Hoo!
