Whats This In The Compaion Bin
6 replies to this topic
#1 mini ian79
mini ian79
  • 67 posts
Posted 16 June 2011 - 09:50 PM
Hi
I have cut away the heel board as the sub frame bolts had siezed solid and was rotten also on the same side there is an oversill fitted so i decided to take alook to prepare myself.
anyway in the photo what am i pointing at as the inner sill doesnt go that far is it some sort of strenghener in the companion box
[attachment=113606:DSCF0982.JPG][attachment=113607:DSCF0983.JPG]
hope this makes sense
cheers
#2 Ethel
  • 25,915 posts
Posted 16 June 2011 - 11:17 PM
Inner sill, once upon a time it was actually all the same the same steel pressing going right across the car from door step to door step. It might have been retained for the seat belt anchor, with countless patches around it.
#3 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 16 June 2011 - 11:21 PM
I think you mean the "closing plate" for the inner sill or sometimes called a "stiffener"
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 17 June 2011 - 03:18 PM
Inner sill stiffener although this is a fabricated one but very similar to the proper part
Welded in place
#5 mini ian79
mini ian79
  • 67 posts
Posted 17 June 2011 - 09:08 PM
Thanks for the advice just to make sure is it just a continuation of the inner sill to the heel board welded to the rear quater panel
thanks again just want to get it right before i start mocking one up
cheers
#6 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 17 June 2011 - 09:14 PM
No it is not welded to the rear quarter panel. The rear arch close out panel is welded to the rear quarter panel and the heelboard, the stiffener is welded to the close out as well as the inner sill. There will be a gap between the quarter and itself.
#7 mini ian79
mini ian79
  • 67 posts
Posted 17 June 2011 - 09:20 PM
wonderful think thats all i need to know i can now make a start
thanks again
