How Do You Pocket A Block?
31 replies to this topic
#1 matthewjtovey
matthewjtovey
    Just On Tickover
  • 8 posts
Posted 14 June 2011 - 09:28 PM
Hi
Im looking at putting a 1275 head (12g940) on my 1990 Mayfairs 998. Ive found so far that i will need to pocket the block. However, i can find no where how you actually do that!!
Could someone walk through the steps for me please.
Also can this be done while still in the car or does the engine have to be removed?
Any photos of the process would be great!
Matt
#2 MRA
MRA
  • 7,607 posts
Posted 14 June 2011 - 09:47 PM
Do you mean like this one....
[attachment=113568:IMG_0784.jpg]
Well this one was done on our CNC mill :gimme:
It depends on how good a job you want ? some people have apparently used a dremmel, however accuracy will be sadly lacking :)
#3 dossy
dossy
  • 271 posts
  • Local Club: Suggestions for North Yorks?
Posted 14 June 2011 - 10:07 PM
What is pocketing? In lehmans terms!!
#4 MRA
MRA
  • 7,607 posts
Posted 14 June 2011 - 10:10 PM
It is the offset machined sections or cut outs on the top of each cylinder, these are to clear the exhaust valve of the 1275 cylinder head (12G940) when used on a small bore engine such as a 998 etc...
#5 mini 4o
mini 4o
  • 318 posts
  • Local Club: corfu mini's
Posted 14 June 2011 - 10:16 PM
hi
just means making space in the block for the valves to go up and down, as the 998 and1275 head have different spacing(lehmans terms)
Imo not worth the trouble, fit a complete 1275 and go
John
#6 matthewjtovey
matthewjtovey
    Just On Tickover
  • 8 posts
Posted 15 June 2011 - 11:24 AM
Well this one was done on our CNC mill :unsure:
It depends on how good a job you want ? some people have apparently used a dremmel, however accuracy will be sadly lacking :cry:
Thanks for the photo and info! How much roughly would this cost to do properly? If the engine was still in the car when taken to the machine shop.
#7 PhilipGCaldwell
PhilipGCaldwell
  • 870 posts
Posted 15 June 2011 - 11:31 AM
its usually 60 Earth pounds
#8 dossy
dossy
  • 271 posts
Posted 15 June 2011 - 11:37 AM
makes sense, thanks for that! i have a 998 but im hoping to upgrade to something bigger, so i dont really want to get too technical with modifications if im not keeping it!
#9 PhilipGCaldwell
PhilipGCaldwell
  • 870 posts
Posted 15 June 2011 - 01:16 PM
stick to 998 :unsure: much more fun, and more reliable :cry:
#10 benb12
benb12
  • 1,483 posts
Posted 15 June 2011 - 01:25 PM
I know you love your small bores but you need to explain why you think a 1275 would be less reliable! I've had absolutely no reliability issues with mine.
#11 MRA
MRA
  • 7,607 posts
Posted 15 June 2011 - 02:14 PM
I have no issues with my 1380 turbo engine either.... :cry:
#12 PhilipGCaldwell
PhilipGCaldwell
  • 870 posts
Posted 15 June 2011 - 02:15 PM
998s are bomb proof
#13 MRA
MRA
  • 7,607 posts
Posted 15 June 2011 - 02:16 PM
It will cost a lot more than £60 if the engine is still in the car when you take it to the machine shop.... and that is assuming that they will even bother to do the job, taking engines out is not normally associtaed with machine shops.....
#14 benb12
benb12
  • 1,483 posts
Posted 15 June 2011 - 02:20 PM
998s are bomb proof
No more "bomb proof" than a 1275. If you can't explain why a 998 is so much more reliable than a 1275 then don't make the claim!
#15 dossy
dossy
  • 271 posts
Posted 15 June 2011 - 02:54 PM
1380 turbo is what i want!!!!!
