What Do You Need Tool Wise For Welding
185 replies to this topic
#121 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 13 October 2013 - 08:48 AM
I have a few patches to do on my mini, I have practiced using the great advice in this thread, but what is the best way to cut out the section that needs replacing and making a perfect plate to fit into the cut out section to create a butt weld. For example fitting a plate in the boot or rear quarter section.
Depending where the rust is I use either a grinder with a cutting disc, tin snips or drill and tinsnips.
For making the patch then cardboard is your freind. If the peice you have cut out is not too mangled then you can flatten it out and draw around it on the card and add bit's that have been cut/rusted off. Or cut a peice card to roughly the right size, put it where the hole is and draw around it. Then you can cut the card out and fold it if need be and fit it in, if it doesn't fit adjust it to fit, then when the card is right then you can trace it onto sheet steel and cut that out. I can try and find a few of my pictures if you like or have a flick through my project.
#122 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 16 October 2013 - 01:07 PM
Sonikk, is your welder settings in the picture on the first page set to min or max? I can't tell on mobile. Thamks
Edited by megamini_jb, 16 October 2013 - 01:09 PM.
#123 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,188 posts
  • Name: Neil
Posted 16 October 2013 - 03:31 PM
The rocker to the left is set to 2 and the power setting is on minimum.
#124 sixtyeight
sixtyeight
  • 630 posts
  • Local Club: forums.minidriver.com.au
Posted 03 November 2013 - 10:57 AM
If you need to make up a cardboard template for a section you can't get to both sides of, I press a piece of card against the hole, and run my finger firmly around the edge so it leaves an impression on the card in the shape of the hole. then cut it out.
#125 brad101
brad101
  • 28 posts
Posted 19 November 2013 - 01:28 AM
a flat piece of copper is good to back pin holes with while you hit with a mig. the pool wont stick to the copper and it leaves a deacently flat back on the weld. or you can use it in many other applications.
#126 sonikk4
sonikk4
  • 16,188 posts
  • Name: Neil
Posted 28 January 2014 - 06:58 PM
Although not directly related to this thread it goes to show you what maybe hiding on the underside of seemingly good panels.
This is the old doorstep of a Mini Special. It did not look too bad to be honest just a little bit of rust on the step to sill flange
f5a2bd14-1938-4dbb-ab26-66fde3fd69a4_zps
However on the underside is this
So what you think may be good and just needs a small section replacing get in there with a mirror and see the true extent of the rust.
#127 rodandtom
rodandtom
  • 998 posts
Posted 28 January 2014 - 07:37 PM
Hi Sonikk,
What make is the joggler you use? I bought a Sealey one and it really doesn't make much of an impression. I am assuming I bought a naff one even though it was £50.
Ta
Rod
#128 sonikk4
sonikk4
  • 16,188 posts
  • Name: Neil
Posted 28 January 2014 - 07:44 PM
Rod thats a bloody good question and the answer is i don't know. i bought mine in 1989 however just nipped out to the garage and its says TAMA Made In Denmark.
#129 rodandtom
rodandtom
  • 998 posts
Posted 02 February 2014 - 10:39 PM
Time to google Tama then :-)
To anybody looking to get some - don't buy Sealey - they are absolute rubbish - and I made sure I didn't buy the cheap ones
Rod
edit:
That didn't take long - search Tama Denmark and you find these: -
http://www.tamatools.com/joggler.php
Edited by rodandtom, 02 February 2014 - 10:41 PM.
#130 KingZog
KingZog
  • 42 posts
Posted 16 February 2014 - 09:23 PM
I'm after some views on this mig welder:
http://www.amazon.co...aw/d/B0083WHLQI
Compared to the well regarded Clarke 135te for use on minis.
What do people think?
#131 sonikk4
sonikk4
  • 16,188 posts
  • Name: Neil
Posted 16 February 2014 - 09:31 PM
Mmm very cheap, now this may be ok but personally never heard of them.
User manual
http://www.rhyas.com/D/53054.pdf
and heres a review of it on the Mig welding forum
http://www.mig-weldi...-new-mig.38309/
#132 KingZog
KingZog
  • 42 posts
Posted 16 February 2014 - 09:37 PM
That's what I thought but the specs seemed similar to the Clarke but then I know very little about welders!
#133 sonikk4
sonikk4
  • 16,188 posts
  • Name: Neil
Posted 16 February 2014 - 09:42 PM
Its basic and it should work but as for how long it will work remains to be seen.
For the money as its half the price of the clarke 135 its worth a punt. But use it as gas and not gasless.
#134 KingZog
KingZog
  • 42 posts
Posted 16 February 2014 - 09:56 PM
If I can't get a Clarke on eBay then may have a dabble!
#135 GrahamHill
GrahamHill
  • 91 posts
  • Local Club: GMOC (Glos)
Posted 28 February 2014 - 08:59 PM
Well I would say how soon do you need a welder. Can you wait until Mid April? We will be launching our own MIG (+MMA function) for £312.
As a non-trader I don't want to do a hard sell but just a let you know it may be worth waiting for...
