What Do You Need Tool Wise For Welding
185 replies to this topic
#76 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,031 posts
  • Name: Neil
Posted 30 May 2012 - 10:30 AM
I will suggest that for welding you have to use so many tools regarding your usage. Welding accessories, plastic welders,1/2" drive click stop torque wrench,plasma cutters,Arc welders,12 piece assorted length elastic tie down etc.
I suggest that this is spam and as such its not allowed on this forum.
#77 sonikk4
sonikk4
  • 16,031 posts
  • Name: Neil
Posted 11 June 2012 - 03:05 PM
Something new to add to the panel clamp part of the tooling from alex-95.
If you have not seen these before they are called ezy earth clamps usually used for earthing stainless steel sinks, but are very handy for clamping panels together. They are very good because they are much smaller than bodyclamps and mole grips. They are about £1 each so are cheaper than normal clamps. Here is a web site from where you can get them www.eleconline.co.uk , but you can probabily get them from electical wholesalers.
Edited by alex-95, Today, 01:42 PM.
#78 rodandtom
rodandtom
  • 998 posts
Posted 05 August 2012 - 03:11 PM
Hi,
Good info.
In your photos you refer to a joggled piece of metal. I can see that its two bends, one below the other to introduce a kink, but how did you do it on a larger piece of metal like the one in your photo?
Thanks,
RodAndTom
#79 sonikk4
sonikk4
  • 16,031 posts
  • Name: Neil
Posted 05 August 2012 - 03:16 PM
I use the joggling tool that is in one of the pictures ie this one and its the item at the top of the picture
#80 rodandtom
rodandtom
  • 998 posts
Posted 16 August 2012 - 07:19 PM
What make Joggling tool would you recommend? There are lots on offer at around £50 - I don't want to buy junk.
Thanks,
RodAndTom
#81 JonnyBMX
JonnyBMX
  • 865 posts
  • Local Club: Rebels
Posted 17 August 2012 - 07:30 AM
Hi guys,
don't know if any of you are interested etc but i have recently got a new respirator for welding, its the 3m 7500 series. 7501 - small, 7502 - medium, and 7503 for large, these are half masks with changable filters! the best part about these masks is that they fit under atleast my welding mask speedglass 100v and i know they fit under the 9100 series too! very good buy IMO quite cheap aswell.
also if any of you are fed up for welding spatter from going down ur neck and in your ears when your welding the underside of a car the 3m welders hood for about £25 is a top purchase i use mine pretty much all the time and yeas the respirator also still fits around this too :) hope this helps guys.
sorry for commendearing your thread neil :)
#82 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,024 posts
Posted 17 August 2012 - 10:27 AM
Thanks,
RodAndTom
Mini mag did a test on which is best http://www.minimag.c...-test-jogglers/.
Edited by alex-95, 17 August 2012 - 10:27 AM.
#83 JonnyBMX
JonnyBMX
  • 865 posts
Posted 17 August 2012 - 10:59 AM
Thanks,
RodAndTom
i have the clarke air one aswell as a normall hand one, not sure which make the hand one is... but both very good :)
#84 sonikk4
sonikk4
  • 16,031 posts
  • Name: Neil
Posted 17 August 2012 - 06:14 PM
I have had the joggler for a long time now and cannot remember where i bought it from. The hole punch in it is very small so not really ideal for plug welding.
#85 JonnyBMX
JonnyBMX
  • 865 posts
Posted 28 September 2012 - 12:35 PM
might be an idea to invest in one of these dust/fume masks for welding from 3M its the 7500 seris (7501 -small 7502- medium 7503 large)
as you can see fits nicely under a mask
#86 106chris
106chris
    Starting My Mini Up
  • 2 posts
Posted 11 November 2012 - 04:30 PM
a good mig is essential,time and patience,the right wire usually 0.6 or 0.8 for cars,always use gas not the gasless rubbish,co2 cheaper but argon mix reduces spatter and less voltage needed,grips are handy for clamping metal,,clawgrips,c grips,etc, drill with wire brush or belt sander if your posh,grinder with slim cutting stones makes cuttin easier,4 inch grinder with backing pad for sanding is neater and quicker.i use a 10s welding glass in my shield.make sure you have good clean metal and if your dealing with rust cut it out otherwise pointless.
#87 Charginglemon
Charginglemon
    Just On Tickover
  • 9 posts
Posted 15 November 2012 - 04:41 PM
Excellent post - thanks for the insight
#88 Mayberts
Mayberts
    Starting My Mini Up
  • 3 posts
Posted 19 November 2012 - 08:50 PM
I'm hoping to do all my own welding, thanks to this post my wife has some idea what to get me for Xmas.
#89 sonikk4
sonikk4
  • 16,031 posts
  • Name: Neil
Posted 19 November 2012 - 08:58 PM
No problem, here to help. :D
#90 Petrol
Petrol
  • 967 posts
Posted 17 December 2012 - 11:07 PM
Thanks for taking the time to post this very useful information. The pics of the pulse welding are a great insight into what I need to achieve before I start welding on our car.
Again thanks, this post has saved me a lot of time.
Pete
