What Do You Need Tool Wise For Welding
#166
Posted 26 August 2016 - 06:42 PM
#167
Posted 27 August 2016 - 12:30 AM
#168
Posted 27 August 2016 - 11:51 AM
Now it boils down to several things.
1: Budget.
2: Abilty
3: Frequency of use.
Now personally I have been hammering my 135TE for a long time (3 full mini body restos, VW T4, various other cars over the years) and it keeps going. Yes I really could do with a more professional unit like for example a Porta Mig but when you are looking at £600+ at the moment I cannot justify one. It's a hobby not a full time job so as and when this dies then I will splash the cash.
So basically that is what you need to ask yourself.
#169
Posted 28 August 2016 - 09:09 AM
Edited by HarriBlow, 28 August 2016 - 09:10 AM.
#170
Posted 28 August 2016 - 08:26 PM
#171
Posted 18 March 2017 - 04:26 PM
#172
Posted 18 March 2017 - 04:32 PM
So after much deliberation I finally purchased my welder, I opted for the Clarke 135te all I need now is an excuse and some time to use it
No excuse needed. So buy a regulator suitable for Argoshield lite or equivalent, a 5kg reel of 0.6mm wire, some spare tips, shrouds, some 0.9mm steel sheet and 1.2mm sheet and away you go.
#173
Posted 18 March 2017 - 04:45 PM
#174
Posted 08 September 2018 - 07:02 PM
Thanks for the thread Neil!
Not sure if this is off topic or not. Apologies if so. Here goes.
How do you get the plug welds ground flush (and seemingly invisible) without thinning the metal too much? Is it just a lot of care with an 80-grit flap disc, or is there more to it than that?
Cheers,
Jim
#175
Posted 08 September 2018 - 09:02 PM
Cheers,
Jim
Hi Jim, i use Roloc discs, which give a far finer finish and removes as much or as little metal as you desire. This is with a Pneumatic die grinder so not as harsh as a electric grinder with a flap wheel.
#176
Posted 08 September 2018 - 09:28 PM
Thanks Neil.
I have a pneumatic die grinder. I'll have a look tomorrow for the additional stuff I need.
Cheers,
Jim
#177
Posted 07 December 2019 - 07:02 AM
#178
Posted 02 March 2020 - 04:27 PM
#179
Posted 02 March 2020 - 06:57 PM
I may have to do my work outside, in a carport. I could put a wind break up. I’m just wondering how much wind/draft we are talking about regarding going gas vs gasless? Or will any outside work be unsuitable for gas. Thanks, great post. I’ve learnt lots and all seems less daunting.
I have used all sorts of things from blankets wrapped on a pallet to act as a windbreak to basically anything i can find. As long as the torch area is protected you should be good. It may take a bit of fiddling around but you will soon know if you are protected enough.
#180
Posted 02 March 2020 - 07:19 PM
Thank you for your reply, that's genuinely helpful.
