At the moment i'm doing a bit of rewiring and making a new loom for my megajolt system and i'm considering putting in a second fuse box to run the extras.
The sort of stuff i'll have running off it is the megajolt (which includes the MJ unit, the coil and the EDIS module) my radio, fuel pump and my spotlights; so a fair few bits that must put a fair bit of extra strain if I wire them all into the standard fuse box.
I'm thinking of getting a fuse box like this: Link - A 6 way blade fuse box.
I was thinking this would be easy to wire by running a large gauge cable from the starter solenoid and splicing it into 6 smaller 20 amp or so wires to each fuse and then I can just power whatever I want from the second fuse box. However most of the accessories i'll only want powered when the ignition is on - Especially the fuel pump and MJ.
So what would be the best way of wiring in a new fuse box that works from the ignition but still is safe enough to have 4-5 accessories running off it?
I should add that wiring is exactly my strongest point either!
