Upgrade Pc Bios
#16
Posted 13 June 2011 - 03:07 PM
When checking for motherboard details I get 000000000000000000000 for motherboard version but manufacturer as Packard Bell Nec. Is there a way of getting via cmd line or is Control Panel the only route?
BIOS is Phoenix Technologies LTD, 20J, 19/05/2006
SMBIOS Version 2.3
Neil
#17
Posted 13 June 2011 - 04:36 PM
I have stripped it down to 2Gb though I still get blue screen.
SMBIOS Version 2.3
Neil
Check the motherboard, sometimes they have the details printed on the board itself.
“ BIOS is Phoenix Technologies LTD, 20J, 19/05/2006
SMBIOS Version 2.3”
The details above don’t really help I’m afraid
There are bits of s/w that can supposedly find the make and model of the motherboard for you, but they are not always reliable! Someone may have one they know to be reliable... but I don't trust them!
Edited by mini77, 13 June 2011 - 05:03 PM.
#18
Posted 13 June 2011 - 06:27 PM
Gigabyte GA-8TRC410MNF-RH
Any help is greatly appreciated...only upgrade from 1Gb as it was running 95%+ on Windows 7 and running dirt slow.
Thanks.
Neil
#19
Posted 13 June 2011 - 06:44 PM
#20
Posted 13 June 2011 - 07:08 PM
rite, give me the brand of ram and speed i.e. pc5300/pc6400 and we'll see what we can do..
Hopefully this is whats needed (I got the RAM from Orca as they had the on line tool).
JetRam DDR2-667
http://www.transcend...m...=1&Func2No=
Thanks for bearing with me on this....I use computers and thats about it.
#21
Posted 13 June 2011 - 07:21 PM
now wen i find things a little hard to pin down i start the testing process...
can you swap out the ram for some corsair? kingston?.. the value stuff i mean.. as some times they do let defective ram slip through their fingers and im not a big fan of transend ram.. may be your board dont like them either..
go back to using your 1gig and see if its ok.. then borrow a friends 2gig and see if thas ok... i have a feeling your board dont like the jetram stuff
#22
Posted 13 June 2011 - 08:13 PM
..ok been looking into this.
Gone back to the 1Gb and all is fine so far., other than the stupidly slow running Booooh.
Will have to find a willing victim (friend) to help me.
Maybe a new home pc is in order????? or would/could a BIOS upgrade help?
Thanks.
Neil
#23
Posted 13 June 2011 - 08:35 PM
download SIW has worked well for me so far, farely safe imo
#24
Posted 13 June 2011 - 08:48 PM
Thanks.
Neil
i, personally, would send the ram back and order some well branded sticks.. i think the board is throwing its rattle out the pram.. i stick to certain brands of ram for good reason
COMPATABILITY.. try some kingston value stuff, cheap, effective and very rarely lets me down for a nice quick upgrade...
did you try both stick by them selves by the way?..
screw it.. just send it back and get the kingston stuff.. you'll thank me
#25
Posted 13 June 2011 - 09:08 PM
Something else to check, if your RAM slots are dusty, give them a clean (compressed air or brush), as if the dust then gets moist due to humidity, it can start causing problems.
#26
Posted 13 June 2011 - 09:39 PM
Download MemTest86, you'll need to put it on something bootable like a flash pen and then boot from that.
It will stress your RAM to high heaven, if there is anything wrong with it, you'll find out!
#27
Posted 15 June 2011 - 06:38 PM
From the motherboard it has the following name.
Thanks.
Neil
I’ve hit a brick wall as regards sourcing a BIOS upgrade, Gigabyte doesn’t list your motherboard in the d/l section of their site...a BIOS upgrade most probably is not what you need anyway.
Edited by mini77, 15 June 2011 - 06:45 PM.
#28
Posted 15 June 2011 - 06:47 PM
Thanks.
Neil
Thanks for taking the time to take a look. I've emailed Orca to see what they think and about sending back for something decent.
Thanks again. Neil
