Road Rally Mini Project
609 replies to this topic
#76 minisi35
minisi35
  • 723 posts
  • Local Club: british mini club shropshire
Posted 27 October 2011 - 10:13 AM
half term week so im not touching the mini, well trying too lol :shy:
#77 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 29 October 2011 - 01:49 PM
what welder are you using? and what type of metal are you using to weld with?
#78 minisi35
minisi35
  • 723 posts
Posted 31 October 2011 - 02:14 PM
im using a mini mig 130 with 0.6m wire, most of the steel is 18swg with the reinforced sections with 3mm steel
#79 minisi35
minisi35
  • 723 posts
Posted 02 November 2011 - 04:42 PM
Back in the garage....
needs a bit of tidying but this is a picture of the nuts ive welded on the top rail
This is actually the second and third dash ive made. The one without the clock was scrap as the new tool i had bought to cut the hole moved out of adjustment and cut the hole 5mm to big!!
#80 benb12
benb12
  • 1,483 posts
Posted 02 November 2011 - 06:56 PM
Superb project! Hopefully I'll see it in action one day as I'm just getting into road rallying myself, with a Maestro though not a Mini. Just working out what modifications I need to comply with the regs and trying to source parts - not so easy with a Maestro it seems. Your fabrication is good, keep it up :)
#81 minisi35
minisi35
  • 723 posts
Posted 03 November 2011 - 09:21 AM
Thanks Ben, if you need any advice on road rallying feel free to ask
#82 minisi35
minisi35
  • 723 posts
Posted 04 November 2011 - 04:34 PM
finally got the dash how i want it......
you can see where i added the lower bracket with a nut welded on it for easy fit
Not a bad crackle finish
#83 minisi35
minisi35
  • 723 posts
Posted 07 November 2011 - 11:33 AM
Dash finished!!!
What do you think?
#84 Risky
Risky
  • 213 posts
Posted 07 November 2011 - 04:44 PM
Looks really good, I love the works style dash!
#85 minisi35
minisi35
  • 723 posts
Posted 11 November 2011 - 05:04 PM
Thanks Risky
Heres one of the finished item with the labels on
#86 Risky
Risky
  • 213 posts
Posted 13 November 2011 - 06:11 PM
Very nice, I'd like to have a dash like that in my Mini, as I'm going for the rally-look (slowly but steadily)
#87 leadly
leadly
  • 779 posts
  • Local Club: [] D.C.M.O.C []
Posted 13 November 2011 - 07:56 PM
Great project so far matey.
Now time to read C4NNON's while the mrs watches bloody x factor!
#88 minisi35
minisi35
  • 723 posts
Posted 22 November 2011 - 02:29 PM
Time to catch up on my work
I fitted the group 2 arches to see how much i have to cut away for clearance
then proceded to make a ******* up of cutting the edge off the arch on the one end, you can see where ive marked to cut the slots for bending to form the new lip
#89 minisi35
minisi35
  • 723 posts
Posted 22 November 2011 - 04:46 PM
then got a strip of metal and reformed the shape of the arch and put the strength back into it
cleaned up a bit
the finished article
#90 minisi35
minisi35
  • 723 posts
Posted 26 November 2011 - 04:32 PM
For those that are interested this is the look im going for :gimme:
