Road Rally Mini Project
609 replies to this topic
#46 minisi35
minisi35
  • 723 posts
  • Local Club: british mini club shropshire
Posted 14 September 2011 - 03:44 PM
Was just about to stone chip the sill and realised i hadnt plated the jacking point( which i wont be using)Posted Image
made a template
these are still the best sheet metal cutters i find
drilled and ready to weld
not my best welding but its sealed the hole
Posted ImagePosted Image
#47 minisi35
minisi35
  • 723 posts
Posted 14 September 2011 - 04:00 PM
job done!!!!!!!!!!
#48 minisi35
minisi35
  • 723 posts
Posted 16 September 2011 - 04:23 PM
Bit more done, have test fitted the boot lid and marked up where the rubber strap is goin
#49 charlietuffery
charlietuffery
  • 14 posts
Posted 19 September 2011 - 05:33 PM
Brilliant job on the rebuild buddy. Just wondering what sort of Sealants and primers etc you would reccomend ?
#50 benjy_18
benjy_18
  • 1,038 posts
  • Local Club: LSMOC
Posted 19 September 2011 - 05:56 PM
looking pretty awesome so far buddy!
will you be driling some venting holes in the oversills?
#51 minisi35
minisi35
  • 723 posts
Posted 20 September 2011 - 10:21 AM
I wasnt going too, the only holes that will be through the sills will be for the roll cage. I hadnt really thought about venting
#52 minisi35
minisi35
  • 723 posts
Posted 20 September 2011 - 10:28 AM
so far ive used granville seam sealer, gravitex stone chip, and hammerite underseal
#53 benjy_18
benjy_18
  • 1,038 posts
  • Local Club: LSMOC
Posted 20 September 2011 - 11:35 AM
its a good idea to put some holes in them, or even on the inner sills. it allows any condensation to evaporate and stops the sills rusting from the inside, out.
#54 minisi35
minisi35
  • 723 posts
Posted 20 September 2011 - 03:43 PM
good point , ive got a couple of holes in the inner sill where ive put wax in. I was going to fill them in but think i will leave them
#55 1977 Loud_Mini
1977 Loud_Mini
  • 896 posts
Posted 20 September 2011 - 08:56 PM
You've got some good welding and fabrication skills, I like the rear boot hook, very rally style. Heres mine on my mini, and the hook cost a fair bit of money really:
Evan.
#56 minisi35
minisi35
  • 723 posts
Posted 21 September 2011 - 09:16 AM
Evan.
Thanks Evan, i was lucky to buy the hook for £7 and got the hooks quite cheap through work. Yours looks great!! did you buy the headlamp covers or make them?
#57 minisi35
minisi35
  • 723 posts
Posted 21 September 2011 - 03:39 PM
finished the boot last night and fitted the mk2 handle
#58 minisi35
minisi35
  • 723 posts
Posted 23 September 2011 - 04:13 PM
Realised after fitting the dash rail that the works dash i had made using the original patterns , wasnt going to fit. This is because the works ones sat forward of the dash rail but my roll cage sits flush with the front of the rail. So i had to modify the "box" so it now sits flush. This also brought up another problem in that the front piece is bolted in 3 places along the top and bottom. The 2 end bolts are now not accessable do i had to weld in the strips of metal you can see in the pic
Im going to have to remake this front piece as its steel and some of the holes need changing. Ive got some nice alloy lined up to do the job
#59 minisi35
minisi35
  • 723 posts
Posted 28 September 2011 - 04:22 PM
bit more progress plated the speedo hole.
First bolted in the plate i had cut out
welded and cleaned up
from behind
#60 minisi35
minisi35
  • 723 posts
Posted 29 September 2011 - 03:30 PM
bit more done,im using different size heater hose so the hole doesnt need to be as big
Templates madePosted Image
handy tool this magnet
not to bad was running low on gas
cleaned up and done, just got to sealer it
