Road Rally Mini Project
609 replies to this topic
#571 rally1380
rally1380
  • 1,893 posts
Posted 13 December 2016 - 06:30 PM
......the arrival of a baby has kerbed my rallying somewhat.
I know that feeling!!!!!   :cry:  :cry:  :cry:  :cry:
#572 minisi35
minisi35
  • 723 posts
  • Local Club: british mini club shropshire
Posted 18 January 2017 - 09:46 AM
Time for a change
Having over specced the car first time around there are some things I have to change to get it to "classic road rally spec"
to do list:
change to twin carbs
swap the side windows to non slider ones
swap the back window back to glass
remove the current front vented 4 pot calipers and replace with single pot solid set up
change flywheel and starter from pre-engaged to inertia type
fit lumeniton distributor
and a couple of small bits
luckily I rarely throw stuff away so I have found most of it in my garage
F1E92E8A-BDEB-477E-9DF5-C247D55A0569_zps
#573 GraemeC
GraemeC
  • 7,438 posts
Posted 18 January 2017 - 11:48 AM
Apart from the windows and brakes, I wouldn't bother making the other changes.
And that flywheel looks like it would also be pre-engaged.
#574 minisi35
minisi35
  • 723 posts
Posted 18 January 2017 - 12:19 PM
I am working to these requirements
http://hrct.co.uk/category-2-mini/
#575 rally1380
rally1380
  • 1,893 posts
Posted 18 January 2017 - 12:51 PM
If you turn up with a HIF44 carb they will not let you run.  HS4, HS6, twin HS, or weber....think Amals are allowed too
#576 GraemeC
GraemeC
  • 7,438 posts
Posted 18 January 2017 - 01:09 PM
Depends on event and scrutineer.  As said on PM to Simon - there are few cars are % legal even amongst the top boys.
Interesting point - When you read the Cat.2 requirements it actually says you have to use twin SUs (if using SUs) - no mention of using a single HS4 or HS6.
Question - given a HIF4 (not 44) was used on MGBs in at least '72 then why couldn't they have been used on a Mini of a similar period?
#577 rally1380
rally1380
  • 1,893 posts
Posted 18 January 2017 - 02:26 PM
Considering the chief scrutineer on the Tour of Cheshire (Simon's first historic event) is the eligibility scrute for the entire country, and with it being the first round of the HRCR championship, I reckon they'll make a point of making sure cars are right.  Yes I agree few cars are fully legal, but better to be safe and put stuff right, than risk a no run......and a carb is an easy spot for them.
That's wrong too. What the cat 2 information on the HRCT website tells us are the 'Permitted modifications supported by documented evidence' that they already know of. So as we all know, the standard mini came out of the factory on a single carb so that's fine to use, but there is documented evidence of the modifications listed, so they are also ok to use.  Where the 'Fish' carbs come in there I do not know as i'm sure they are 'period'.....got a Minnow Fish (or is it a Reece) on a manifold doing nowt that I've always meant to do something with.....I digress!
Correct. If you can get proof of use in period then no problem at all.  Hence why period magazine articles are brilliant.  That's why I've got a copy of a CCC from December 74 with an article about Pat Ryans wild rally mini....almost space-frame rear with coilovers and an 8 port head. So I can use these modifications (if I wanted) as I have documented evidence.....but as my car stood (pre accident) it met all of the parameters the HRCR state as ok on their technical site to avoid issues.  The rebuild might be different!
#578 GraemeC
GraemeC
  • 7,438 posts
Posted 18 January 2017 - 03:08 PM
Yep - we've discussed that on PM too. I'd agree that at the event it will be policed hard and to Paul's rules. Pragmatism isn't always top of the agenda.
Fair point - I'd missed that line at the top when scanning through earlier, I did think it would be odd.
Its not the best written website for a technical reference site, still points you at the 2010 Blue Book in places.
#579 minisi35
minisi35
  • 723 posts
Posted 18 January 2017 - 03:35 PM
Just means a load of work but when its done its done
The parts I am changing are luckily all the parts I have in the garage so the cost hopefully is going to be a minimum. The reason for the twin carbs is purely as I have a set
Luckily I found I have an early verto flywheel that I had from some engine or other. This one has a 107 tooth ring gear to which I can use the inertia starter with again saving the cost of a different clutch hydraulic setup etc
The brakes were taken off my old cooper when it was converted to a metro turbo set up. The calipers are sourced through work but the old units cover the surcharge
Hopefully the only cost will be my time once the wheels and brakes are then sold on
#580 keefr22
keefr22
  • 591 posts
Posted 18 January 2017 - 09:56 PM
It's weird the things that stick in your memory. I remembered that Mini article from when I had an annual sub. to CCC, & it's weird I did recall it as I was only into Escorts back then & totally dismissive of Minis! But I thought I remembered it being sort of a 'Super Saloon' racecar? Unfortunately I gave all my CCC's away a few years back, but I just did a search on flea bay & a copy of the Dec '74 issue comes up with a clever looking (for the time) cutaway photo on the cover with the caption 'Ultimate Mini Racer' - & it has just one seat, is on pure slicks & has a very strange cage design that I don't think would pass scrutineering now! Is that the car you mean Dave? I'd always thought  that the documentary evidence to allow period mods to be used had to relate to the motorsport discipine you wanted to use them in - ie for a rally car it has to be a rally article? Was I wrong in that? Wouldn't be the first time!
Anyway. I just bought that copy purely for nostalgic purposes. It cost £5.70 for a mag with a 25p cover price. Nostalgia is more expensive than it used to be...!!
Keith
#581 rally1380
rally1380
  • 1,893 posts
Posted 18 January 2017 - 10:42 PM
Keith
Not wrong about the point you made Keith...rallying mods for rallying yes. But you are looking at the wrong car....correct issue though. Enjoy the actual pat ryan car when you see it.
#582 keefr22
keefr22
  • 591 posts
Posted 18 January 2017 - 10:46 PM
Keith
Cool, thanks Dave! I have no idea why that race car would have lodged in my memory though!
#583 minisi35
minisi35
  • 723 posts
Posted 26 January 2017 - 06:41 PM
Windows sorted
Before
235A2093-7064-41C5-919A-3565619DE9FB_zps
New ones ready to fit
27D23681-F4FA-4AC3-8E41-7622CFA7C654_zps
All done
9443A610-A3E7-40C0-9ADE-C75539631FA5_zps
#584 minisi35
minisi35
  • 723 posts
Posted 27 March 2017 - 02:51 PM
Time for an update. Leading up to the rally a lot of time was spent changing parts to meet the requirements of historic rallying.
Some of the changes were:
From this
5941EECA-CD89-4E89-A71A-6C11D1F7645C_zps
To this
1440D5C5-DBC7-4B40-885F-67C58CE6B194_zps
From this
4FFB4D2D-257E-4BE0-96D0-67954A42D079_zps
to this
00FC0FDF-5A73-4F1F-87CF-81A6618786FA_zps
A lot of midnight finishes!!
#585 minisi35
minisi35
  • 723 posts
Posted 30 March 2017 - 11:31 AM
Update time, the pictures in my previous message were on the lead up to the tour of Cheshire. Many late nights getting the car ready but finished the day before the event.
Scrutineering on the night before went without a hitch. It took a bit of time to calibrate the trip computer to the organisers measured section but got it all sorted.
The event itself was fantastic and I will do a write up sometime.
Long story short our event ended with a coming together with another car on a single track road.
afa4eb3d-c349-49d2-acc5-bbe65c05c3a0_zps
Luckily it looks worse than it is. It will need ,A panel,wing,front panel, inner wing and bonnet. The subframe and floor have been checked and measured and show no sign of movement .All the damage has been to the top corner of the wing/headlight area.
88D3F0A7-5FA7-42AB-AB0F-FD497EE85657_zps
This is how it currently looks with its new fibreglass bonnet. Just need the time to get the panels on now!!
    Bing (1)
