I had 2 more motors one of which was good and worked when plugged into the new loom but the wheel box threads were too far gone
So it was just a matter of changing the wire and spindles, if you have never done this before then it's quite simple. Remove the 4 small bolts off the cover on the motor. Inside you will see a wheel with the linkage attached
Remove the circlip and the washer underneath and disconnect it. Then it's a case of doing the same with the old motor and reversing the procedure ( it was cleaned and regreased before the cover was bolted down)
Another job done and a celebratory beer !
