Road Rally Mini Project
609 replies to this topic
#421 keefr22
keefr22
  • 591 posts
Posted 13 February 2013 - 11:05 PM
Good luck with that lot, looks like you've opened a right can of worms....!!
Edited by keefr22, 13 February 2013 - 11:06 PM.
#422 GraemeC
GraemeC
  • 7,438 posts
Posted 14 February 2013 - 08:32 AM
They're standard factory splices. You'll come across a few, especially in the earth cables.
#423 minisi35
minisi35
  • 723 posts
  • Local Club: british mini club shropshire
Posted 14 February 2013 - 02:40 PM
Ahh right thanks for the info, im still changing them and soldering the joints. Piece of mind :proud:
#424 keefr22
keefr22
  • 591 posts
Posted 14 February 2013 - 02:44 PM
Yeh,piece of mind indeed, & if that's factory fitment it's no wonder Mini's had such a bad reputation for electrics, either rightly or wrongly!
#425 GraemeC
GraemeC
  • 7,438 posts
Posted 14 February 2013 - 02:45 PM
Some argue a well made crimp is better than solder as it isn't as prone to failure due to vibration and dry joints etc. Although if I remember rightly from the looms I've pulled apart and reworked, some of the factory joints use both crimps and solder.
#426 minisi35
minisi35
  • 723 posts
Posted 27 February 2013 - 05:14 PM
Had a week off now I'm back sorting out the mess.
Wired a new wiper plug in
#427 minisi35
minisi35
  • 723 posts
Posted 03 March 2013 - 08:13 PM
Right, update! I've removed all the wires that I don't require ie heated rear screen switch , fog lamps , interior light etc
All the bad joins are soldered and heat shrunk . The fuse box is almost done though I need to rewire all the brown wires from the starter to the fuse box. Hopefully finished tommorrow !!
#428 minisi35
minisi35
  • 723 posts
Posted 05 March 2013 - 10:45 PM
Almost finishing the wiring .didnt need this lot!
One more night and it should be done for now until I can test it with the motor in
#429 keefr22
keefr22
  • 591 posts
Posted 06 March 2013 - 12:02 AM
That saved a bit of weight then...!! :proud:
#430 minisi35
minisi35
  • 723 posts
Posted 09 March 2013 - 10:21 AM
Almost finished! Just have to run the new wiring to the relays for the headlamps/side and indicators and I can wrap the wiring for neatness
#431 minisi35
minisi35
  • 723 posts
Posted 22 March 2013 - 05:23 PM
Right im happy with the wiring and done as much as i can without the engine in . Now onto the engine
#432 keefr22
keefr22
  • 591 posts
Posted 22 March 2013 - 08:58 PM
That looks very tidy! Really neat to start trying to sort ours out, but i'm dreading it...!!
#433 Archived4
Archived4
  • Archived
  • 822 posts
Posted 22 March 2013 - 10:07 PM
brilliat updates! loving this! where did you get your seat bars from to weld in?
#434 minisi35
minisi35
  • 723 posts
Posted 23 March 2013 - 10:11 AM
Thanks both
I got them off TopCatCustom who is a member on here. Here's his web address
http://www.topcatcustom.co.uk/
#435 minisi35
minisi35
  • 723 posts
Posted 26 March 2013 - 09:20 PM
I've the the light!!! Big step as I put some power to the fuse box to see if it all worked. Side, brake and indicators all ok!!! So far I'm chuffed !
