Road Rally Mini Project
609 replies to this topic
#376 minisi35
minisi35
  • 723 posts
  • Local Club: british mini club shropshire
Posted 17 January 2013 - 11:17 PM
Back on track , had a busy week modifying the seat side mounts to get them to sit right. Had to cut quite a bit off the cobra mounts to get the passenger seat right and a low as I can
Then fitted the battery cable and secured it. Just need to put on the end for the cut off switch
Also had to mount the seat belt points in a different place as the position of the new seat and the new rails blocked the old mounts. These will be welded from underneath before any events. I secured all the brake and fuel "p" clips with Allen bolts bolted from the outside so they can be moved out of the way when I do weld the anchorage points
And finally modified the rear seat so that the pipe work has plenty of room under the seat
#377 rally1380
rally1380
  • 1,893 posts
Posted 18 January 2013 - 10:59 PM
Looking good.....i need to play catch up now!
All looks very neat and tidy - i'm sure a scutineer will love it.
Where did you get your battery cable from and what rating did you get?
#378 minisi35
minisi35
  • 723 posts
Posted 21 January 2013 - 11:18 AM
I hope so Dave, its taken enough time and money to please them.................. Have you seen the new regs for the welsh events on noise?
The cable im using is 16mm 105amp
#379 keefr22
keefr22
  • 591 posts
Posted 21 January 2013 - 01:57 PM
I haven't bothered to look - is anyone going to be able to pass them then....??!!
Keith
#380 minisi35
minisi35
  • 723 posts
Posted 21 January 2013 - 02:11 PM
Well its still 98db@ 0.5meters from the rear but now they test from the side at 2.0meters@86db
The results of some or the pre tests are interesting
http://www.ldmc.org....est Results.pdf
#381 keefr22
keefr22
  • 591 posts
Posted 21 January 2013 - 02:34 PM
Very interesting - as I think you suggested before, the Escorts are going to be struggling, and some of them look like they may have problems even on stages or hillclimbs..... If that was a representative entry list for an event, there wouldn't be many starters!!
The last Ibiza is interesting - I've got a stage prepped 2.0 GTi as well as the Min, that the boy has been making noises about maybe re-trimming (we've still got all the interior for it), & as it's running a standard motor, looks like that would pass if he wanted to have a go...!!
I hope your Min gets through OK after all the work you've done to it...
Keith
#382 rally1380
rally1380
  • 1,893 posts
Posted 21 January 2013 - 05:59 PM
Weird results.
Standard mk2 escort 1600 with standard exhaust making 89 dB @ 2m!! eh??? how can proper road rally escorts pass then??
Might have to fabricate a 'magic' valve to quieten things down if mine tests loud. May invest in a cheapo noise meter to check it.
#383 keefr22
keefr22
  • 591 posts
Posted 21 January 2013 - 08:51 PM
Weird results.
The 2.2 making 100 at the rear & the same at the side intriqued me! Must have been a full on stage car just taken along to see what it made? That 'standard' 1600 must surely have had a duff exhaust to be that loud?
Is that the modern equivalent of the brillo pad up the tailpipe we used to use....??!! :D
#384 minisi35
minisi35
  • 723 posts
Posted 21 January 2013 - 09:04 PM
I've been chatting to cooperman about it and has given me this advice;
What you do is to weld a 'fin' inside the end of the pipe going about 2" into the pipe in line with the flow and made from, say, 1.5 mm steel sheet. The end of the 'fin' projects about 1/2" out of the end of the pipe and you make some saw cuts into the 'fin' about 1/2" long, i.e. up the the pipe end. Then if it's too noisy you bend the extending pieces to make small deflection flaps, in both directions, to about 45 degrees from the flow direction. That deflects the noise a bit so that with the noise-meter to one side at 0.5 metres away it receives less direct noise. It does knock a db or 2 from the reading.
#385 keefr22
keefr22
  • 591 posts
Posted 21 January 2013 - 09:11 PM
That's cunning!! I do wonder what the noise scrutes will make of it though...?
#386 jaydee
jaydee
  • 8,565 posts
Posted 21 January 2013 - 09:20 PM
What do the regs say, are you allowed to run a bolt-on exhaust tip or you need the exhaust to be welded from the manifold to the end?
#387 keefr22
keefr22
  • 591 posts
Posted 21 January 2013 - 10:06 PM
So far I can't find anything in the Blue Book regarding that, but it could just be covered in individual events ASR's. All I can find on this issue so far is;
5.17.7. Temporary Silencers, by-pass pipes or the
inclusion of temporary parts to achieve silencing
requirements are prohibited. Officials may refuse to
carry out Sound Checks on vehicles utilising temporary
parts in exhaust systems. Organisers are empowered to
exclude in such situations.
Actually, on reading it again that does actually cover bolt on tips, which would be determined as temporary parts, but it doesn't seem to cover Coopermans mod...
#388 jaydee
jaydee
  • 8,565 posts
Posted 21 January 2013 - 10:43 PM
Ok thats out of the regs but you can try it anyway at your own risk.
Theres also the italian way, racing tape a flange on the pipe, then bolt on your custom tailpipe which will be obviousely longer.
After few miles, unbolt it, remove the tape, refit the custom pipe. Job done and no one will know. Maybe..
#389 keefr22
keefr22
  • 591 posts
Posted 21 January 2013 - 10:59 PM
Except the Blue Book also has this reg.
"4.1.6. A further sound test of the same vehicles must
be made on any road sections, and these should be
manned by a Driving Standards Observer and/or Judge
(37, 38, 140(i), 141(a), G.7.8, G.11.2) qualified to carry
out their duties by experience.
Sorry Simon, de-railing the thread a bit now..."
keith
#390 joewf10
joewf10
  • 382 posts
  • Local Club: on lookout
Posted 21 January 2013 - 11:05 PM
can i just ask what you name is? i think i might know you lol
