Road Rally Mini Project
609 replies to this topic
#361 minisi35
minisi35
  • 723 posts
  • Local Club: british mini club shropshire
Posted 10 January 2013 - 02:12 PM
The trouble is they changed alot of the rules to make it harder to logbook, hence why Andy Burtons 306r4 is no longer used. Now that was a car!!!!!!!!!!!!!!!
#362 Tahiti Joe
Tahiti Joe
  • 663 posts
Posted 10 January 2013 - 03:20 PM
They are indeed always changing the rules and regs, the MSA have been under a lot of pressure from the FIA recently regarding safety, both for drivers and spectators. Although they always keep putting the bloody minimum weight limits up for stage rallying, bit of a pain for anyone using a mini! :P
Cars looking fantastic though, your miles ahead of me! :D
#363 keefr22
keefr22
  • 591 posts
Posted 10 January 2013 - 04:23 PM
Certainly was, I loved that Pug! Real shame they got rid of cars like that, simply because the engineering in many of them was so good, & they were so entertaining. It's one of the things I still like about hillclimbs & sprints, as Formula Libre cars can still be used.
It's surprising how many rules are still the same over many years though - I recently found my 1978 Blue Book, & a lot of the rules are very similar, just been tweaked some over the passing decades!! I do have to say that the minimum weight for a stage rally car that Tahiti Joe mentions is another new one on me! Good job we're intending to stick to hillclimbs for the time being, withe everything I'm not aware of!!
K
#364 minisi35
minisi35
  • 723 posts
Posted 11 January 2013 - 10:10 PM
Minimum weight!!! Christ I need to look at the new blue book just incase, surely they could only do it as a percentage of the manufactures listed minimum weight,
One I have heard of being enforced so far this year on road rallies is the 86db 2metres from the side of the car. New standard cars have been tested and failed. Loads on the rally forum about it, and Lampeter have put the results on their website. Carmarthen are now organising a test night for next week, and north Wales have one the week after that.
Last time the mini was tested it was 92db but the limit was 98db. As I havnt sorted an exhaust for the car yet I will need to find the best flowing but quietest exhaust !!
#365 rally1380
rally1380
  • 1,893 posts
Posted 11 January 2013 - 10:19 PM
That makes mine over the limit too. Twin maniflow systems are too loud me thinks
#366 rally1380
rally1380
  • 1,893 posts
Posted 11 January 2013 - 10:30 PM
Was your reading of 92db measured at 0.5m though?
I'm concerned about this news (not got my 2013 Bluebook yet) as my first eevn is about a month away....so need fiddling/bodging time..
#367 keefr22
keefr22
  • 591 posts
Posted 11 January 2013 - 10:50 PM
Rats!! Our manifold has cracked & the Min is off the road until we can get a new one (after payday unfortunately), as I would have loved to take it down & get it tested. I have a suspicion that with the single Weber & stage 2 LCB manifold with just a rear box that it would be too loud even for hillclimbs which is still 96db at 2.0 metres! I think we'll probably go for a complete new system & get some filters for the Weber's trumpets...
The 2013 Blue book is online here;
http://www.msauk.org...sp?article=1158
#368 jaydee
jaydee
  • 8,565 posts
Posted 12 January 2013 - 12:48 AM
Wow MSA is changing each year worse..bad times for you i'm in the continent :P
Back on topic, at what RPM they're gonna test that? Because if thats at full power even a bog standard mini wont pass...
#369 rally1380
rally1380
  • 1,893 posts
Posted 12 January 2013 - 08:49 AM
Its at 2/3rd's maximum RPM.
Just had a look at some proposed regs...and straight cut gears in the transmission are looking at being prohibited!
#370 minisi35
minisi35
  • 723 posts
Posted 12 January 2013 - 08:55 AM
thanks keith will have to print it off and highlight the sections that apply
rally1380
I know , yes it was at 0.5metre, and i do wonder if they are doing it from the side of the car as the escorts transmissions seem louder then the exhausts. Right time to check the blue book. I use the maniflow twin box system so does anyone know if the rc40 is quieter?
What event have you entered?
#371 minisi35
minisi35
  • 723 posts
Posted 12 January 2013 - 09:07 AM
Anyway the last couple of days ive almost finished the fuel lines. Had a bit of a ******* up with the first attempt as i managed to kink the pipe trying to put the bend through the boot. So had to root another piece in front to back. Just got to put some "p" clips onto the fuel hose to tidy things up
Also has anyone had trouble fitting the rear cardboard piece of the headlining the fits in the corner between the side and rear glass, what a pain in the a$%£. Got fed up with trying so fabricated some vinyl to do the job and glued it in place
#372 rally1380
rally1380
  • 1,893 posts
Posted 12 January 2013 - 09:20 AM
rally1380
I initially paniced and thought that tests were taken at 2m and lowering the limit would cause me problems. My twin Maniflow system passed the old 0.5m test with ease so i can only assume i won't have a problem with new rules. Cooperman runs a maniflow back box and a rc40 centre which quietens the system down i assume?
Its the straight cut gear ruling that i'm concerned about....no way to temporary fix that one!
I think you are 100% right....its the escorts they are after. I don't blaime the MSA really, as some escorts are full on stage cars with normal body work and make silly amounts of noise. To be honest i can't really point the finger...my car ain't exactly standard!!!! :D
Tour of Cheshire (day time historic) is my first event, but got road rally and 12 car lined up for march also. Autosolo next weekend too.
The question you asked about the card C pillar covers.....they go in when before the window rubbers go in.
#373 minisi35
minisi35
  • 723 posts
Posted 12 January 2013 - 09:29 AM
rally1380
Ahh that will be why i couldnt get them to fit. Are you doing the moonbeam?
#374 rally1380
rally1380
  • 1,893 posts
Posted 12 January 2013 - 09:34 AM
Doubt it. Its the Tour of Cheshire the weekend before and can't afford to do both really. Would like to do as many rallies as possible but budget needs to be expanded before i do that. Will probably to the roamerlite again seeing as we are still very much beginners/novices.
#375 jaydee
jaydee
  • 8,565 posts
Posted 12 January 2013 - 07:55 PM
Try to test it a friendly MOT station.
A guy i know over here who does road rallying and owns several classics, he runs a MOT station so i'm used to pop down when i need, very useful :)
I'm running a twin box centre exit RC40 + a cooper freeflow, when using an air box and a single carb the things is below 90db at about 4.5k rpm.
With a single HIF44 + ram pipe and sock filter i get close to 95db, but noticed cars with other exhausts (maniflow, sportex etc) are slightly noisier when revved.
I have to work out if twin HS2s + ram pipes and socks will make the bloody thing even noisier
Edited by jaydee, 12 January 2013 - 07:55 PM.
