Road Rally Mini Project
609 replies to this topic
#286 minisi35
minisi35
  • 723 posts
  • Local Club: british mini club shropshire
Posted 10 October 2012 - 03:39 PM
No welding so far this week as im waiting for 2 batteries for my welding helmet, so ive done a bit of plumbing
Have got the clutch hose and and the servo hoses attached
and fitted the lamp bar and front bumper
#287 minisi35
minisi35
  • 723 posts
Posted 12 October 2012 - 09:42 AM
Batteries came for the welder so finished off the drivers side with the extra mountings for the harness crutch strap. The bare metal was starting to show signs of surface rust so gave it a coat of black. I will do the rest of the floor when ive welded in the other side mounts
#288 keefr22
keefr22
  • 591 posts
Posted 12 October 2012 - 09:50 AM
Apologies if you've already mentioned this during the thread, but my son has now been bitten by the bug & is aiming to do a couple of road rallies next year. One of the things that I think may cause him a slight problem is the pretty pathetic wipers that our Min has. I do know that was a standard feature of most 70's cars (I had to put up with it when they were new!) but is there anything that can be done now to improve them? Are you doing anything on this build, or did you do anything on your previous car?
Continuing good work on the build, I think we may be investing in some of those seat bars & harness eye mounts too....
K
#289 minisi35
minisi35
  • 723 posts
Posted 12 October 2012 - 10:56 AM
K
hi Keefr , i have always used the original later wipers with the "u" hook fitting and a good quality blade. The only mods i have done is to tweek the spring a bit tighter in the arm to allow it to have more pressure against the screen. Also on my current mini i have the hoses attached to the arms pic below
#290 keefr22
keefr22
  • 591 posts
Posted 12 October 2012 - 12:35 PM
Thanks for the quick reply. I think I'll have to check what ours is fitted with, & I bet giving the screen a really good clean will help too! I like the hose onto wiper arm trick, used to use it on my Escorts, but had forgotten all about it!
Thanks again
Keith
Edited by keefr22, 12 October 2012 - 12:36 PM.
#291 bikerjohn
bikerjohn
  • 74 posts
  • Local Club: mad manx minis
Posted 12 October 2012 - 04:30 PM
Just a thought, but if your mini is early 70's then you may benefit from fitting the later 2 Speed wipers from a later car and using good quality wiper blades such as Bosch..
I also used to use a product on the screen called "Rain off" or "Rain-X"
see review here http://www.autoexpre...rain-repellents
Hope this helps, John
#292 keefr22
keefr22
  • 591 posts
Posted 12 October 2012 - 05:54 PM
Thanks John, it's a 79 but it's a bit of a bits & pieces car, so I don't know which wipers we have. Shall check tomorrow.
Keith
#293 bikerjohn
bikerjohn
  • 74 posts
Posted 12 October 2012 - 07:42 PM
Another Old dodge to clean an old screen is to TCut it the polish but the screen must be immaculately clean before you use TCut on it.
Whilst my addled brain is still working instead of spending loads of money on spotlight steady's cut a jubilee clip in half opposite the adjuster and drill a hole the size of a pop rivet in each end attach one end with a to the spotlight the other to the front panel and hay presto no fluttering lights :)
Another tip that will save you some problems is to us "c" clamps for the exhaust like these below
http://www.minispare...350/C-AHT97.jpg
In addition to this if you weld a 8mm nut on edge on the side of the exhaust both sides of the Join and lock-wire the Joint as well as the C clamps it should prevent it coming off on Whites( unclassified rough roads marked in white with a narrow black boarder on a road rally) or heavy landings..
#294 minisi35
minisi35
  • 723 posts
Posted 13 October 2012 - 03:31 PM
Ahh the old tricks still stand the test of time the jubilee trick is what I use on my current rally mini.
I have seen the exhaust tip on a mk2 escort so I will be using that one on the exhaust when I get round to it
Thanks John
#295 keefr22
keefr22
  • 591 posts
Posted 13 October 2012 - 05:44 PM
Thanks John
They do indeed - I used the exhaust tip on a Mk1, after copying it from a works car...!!
K
#296 1984mini25
1984mini25
  • 8,784 posts
Posted 14 October 2012 - 06:22 PM
Spent some time getting all the sound deadening off the rear floors, christ theres some weight in that stuff
decided to make the rear parcel shelf a neater sealed version
im happier with that, got the boot sealed off now
I know it's a while ago, but us mini owners do tend to hoard mini stuff. You wouldn't happen to still have that parcel shelf section?
Edited by 1984mini25, 14 October 2012 - 06:23 PM.
#297 minisi35
minisi35
  • 723 posts
Posted 18 October 2012 - 03:43 PM
with haloween coming.................... lol
#298 minisi35
minisi35
  • 723 posts
Posted 19 October 2012 - 04:26 PM
Has anyone else had to use reducers on the heater matrix pipes? All my planned pipework in the engine bay is 1/2" and the matrix is 5/8 so i decided to knock something up that would also look alot neater through the bulkhead.
A friend gave me a steel 5/8" pipe joiner which i cut in half, in my bits and pieces i found some 1/2" steel sleeves but i cant remember what they are for but they were an inch long
They were welded together and the welds smoothed down. Then i found an old heater valve fixing which i cut in half just to use the flange. This was drawn around so i could make a copy for the other one of the pair im making
The 2 bits were then welded together from both sides and the welds filed to be nice and neat
A coat of paint finished the job and another one made for the other side
#299 minisi35
minisi35
  • 723 posts
Posted 24 October 2012 - 01:43 PM
been busy with various things but have finally got the other side seat rails in
#300 keefr22
keefr22
  • 591 posts
Posted 24 October 2012 - 02:42 PM
My son is still toying with the idea of trying to do a road event or two, but when I sit in the car with him, as we're both on the hefty side, it's a bit comical trying to read maps when he's driving, so when we put the seats in properly he's thinking of putting the navs seat a bit further back than the drivers (although I've no intention of navigating for him so hopefully he'll find someone smaller!) - I take it that's not a problem you have with your nav?!
Those seat rails do look very neat indeed!
K
