Road Rally Mini Project
609 replies to this topic
#256 minisi35
minisi35
  • 723 posts
  • Local Club: british mini club shropshire
Posted 14 September 2012 - 05:33 PM
Couple more hours spent in the garage , finished of the passenger door with its chrome finishing strips and test fitted it
The door didn't fit too bad but I needed some really thin metal for shims but the only thing thin enough was this filler spreader so it was sacrificed to do the job...
#257 minisi35
minisi35
  • 723 posts
Posted 17 September 2012 - 10:44 PM
Postie was busy today. The right size rear quarter lights came and also C4NNONs weld in seat mounts came as well though they will be for another day
Anyway got in from work and fitted the rear windows
First fitted the rubber
Then threaded the string into the rubber
Then fitted into place and the string removed and in it went
Job done
#258 matthew25
matthew25
  • 57 posts
Posted 18 September 2012 - 08:13 AM
Like the window mounting....will steal that idea!!!
snap very good idea cheers
#259 minisi35
minisi35
  • 723 posts
Posted 20 September 2012 - 03:46 PM
couple more jobs done..........
got the wipers back on
had to re-tap the master cylinder bolts
forgot what a pain the centre switch panel is to fit!!!
the view from inside
#260 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 21 September 2012 - 09:47 AM
I like your interior light!
#261 minisi35
minisi35
  • 723 posts
Posted 21 September 2012 - 06:14 PM
It's so I can see to weld your seat mounts in :) lol
#262 minisi35
minisi35
  • 723 posts
Posted 23 September 2012 - 08:36 PM
My new purchase came Friday :)
#263 rally1380
rally1380
  • 1,893 posts
Posted 23 September 2012 - 09:09 PM
nice tyres!!!!!! Will you be ready for the rally?
#264 keefr22
keefr22
  • 591 posts
Posted 23 September 2012 - 10:42 PM
They do indeed look like nice tyres - but will they give you much traction/grip on muddy whites? (or are muddy whites a thing of the past on road rallies - just like me?!)
K
#265 minisi35
minisi35
  • 723 posts
Posted 24 September 2012 - 06:47 AM
Well I've got through many a white on standard road tyres. People also use these for rallycross so there must be some grip but will test them myself before I do an event ( still a long way off)
#266 keefr22
keefr22
  • 591 posts
Posted 24 September 2012 - 07:56 AM
I'll be interested to hear what they're like when you do,as we're going to have to find a good wet tyre for hillclimbing, & they do look like they could be good for both wet & dry tar....
Can I ask if you'll be fitting towing eyes or straps front & back to your car? If so, do you know where? I've been having a look at ours & can't really see anywhere you can. I noticed Warning634 has attached one to his sumpguard, but we think we'll probably remove ours as it won't be needed for hillclimbs. I'd have thought they'd have been required for race Mini's but can't find any pics with them fitted!
K
#267 jaydee
jaydee
  • 8,565 posts
Posted 24 September 2012 - 10:58 AM
Keefr22, I have fitted mine to the front subframe as per original towing point. Most cars i've seen are like this.
I dont have one at the rear, but mate has fitted one bolted to the rear subframe, you have to cut a hole in the valance for this.
#268 keefr22
keefr22
  • 591 posts
Posted 24 September 2012 - 11:13 AM
Thanks jaydee, I sort of guessed it would have to be somewhere on the subframe, but couldn't see an original tow point on there! I've ordered a couple of Haynes manuals so hope things like this will become a bit clearer!
K
#269 minisi35
minisi35
  • 723 posts
Posted 24 September 2012 - 07:26 PM
K
Will try and get a picture of mine, the rear ones I was going to use some heavy duty exhaust "u" clamps mounted to the rear subframe
Was in the garage tonight and suddenly thought I'd better check for my own piece of mind that the new wheels do fit over the vented disc conversion
Close but they fit
#270 keefr22
keefr22
  • 591 posts
Posted 24 September 2012 - 07:42 PM
Thanks I'd appreciate that.
I like those calipers! Apologies if you've already mentioned it, but what diameter are your discs?
K
PS I finally remembered to ask my son what rally we marshalled on, but he can't remember either, other than it was run by Gwendraeth Valley MC, not Teifi as I thought!!
Edited by keefr22, 24 September 2012 - 07:45 PM.
