Road Rally Mini Project
#181
Posted 19 June 2012 - 08:15 PM
Was wandering what sort of tyres you use for night events as i realise some rallies can be quite rough? (but fun tho eh?)
I'm slowly building my clubman into a road rally car and unsure whether something like Maxsport RB1 gravel tyres are needed or just go down the sticky Yokohama route and take it easier on the 'whites' as these tend to be small percentage of overall event length??
#182
Posted 20 June 2012 - 10:16 AM
#183
Posted 20 June 2012 - 11:24 AM
I know tell me about it, i had a chat with a scrutineer on the last event i did and there is ways round some of them, ie using carpet on the roof instead of a full headlining. But i will be using vinyl covered alloy door cards to get round them, but the back seat has to be there!Ah just found the "road rallying" section, a bit tighter than the regs for special stages!
#184
Posted 20 June 2012 - 11:59 AM
oh the whites can cause chaos, cant tell you how many times weve been in a queue waiting for a car that is stuck on white because they cant get grip. We run in the semi expert class which run mid field (around number 40 -60) so if you can imagine the state of some of the muddy/grass tracks they use after that many cars have gone sliding through!!Great looking build.
I always use "gravel" tyres on the front and road tyres on the rear. Ive used both maxsport RB1 and colway rally plus ( bought a load off a guy) both are pretty good with the maxsports better on the real muddy stuff. One thing you will need to get used to is how much they move/ roll compared to normal road tyre, but you just adapt to using them. They are also higher profile usually which means slighty better ground clearence but you may have to modify the front of the arch so they dont catch(as ive done earlier in this project)
If you need any advice on road rallying just let me know
#185
Posted 20 June 2012 - 06:47 PM
my friend is looking at rallying his mk1 polo (
#186
Posted 21 June 2012 - 08:02 AM
Well my current car uses seats and harnesses that are out of date, they just have to be in good condition and securely mounted.posting on behalf of a friend
my friend is looking at rallying his mk1 polo () does his bucket seat have to be in date and the same with the harnesses as he said he has seen some people without bucket seats on a road rally in north/mid Wales
this is the official line but if in doubt the mas blue book is online
Technical Regulations
18. In addition to complying with Section J all cars
competing in Road Rallies must comply with the
appropriate part of the following:
Body
18.1. bodywork must represent the manufacturer’s
original profile and may include any optional extras
available directly from the manufacturer.
18.1.1. Bumpers must be fitted.
18.1.2. Paintwork must be one colour or manufacturer’s
original colour scheme. No primer is to be visible.
18.1.3. Vehicles must not have wheel arch extensions,
unless fitted by the manufacturer as a standard item to
the body shape.
18.1.4. All major internal trim as fitted to the body type
by its original manufacturer when offering it for sale
must be retained. This trim will include headlinings,
inside door panels, carpets and rear seats.
18.1.5. Front seats may be improved or replaced.
18.1.6. The trim, including the rear seat may be cut to
allow the fitting of a safety cage.
18.1.7. If equipped with a non standard fuel tank it must
be separated from the driver/passenger compartment
by a protective bulkhead of non-flammable material
preventing the passage of fluid or flame.
18.1.8. Full harness seat belts may be fitted.
18.1.9. Guards may be fitted beneath the vehicle to
provide protection from damage.
#187
Posted 23 June 2012 - 07:21 AM
#188
Posted 23 June 2012 - 05:32 PM
Car is getting painted next week!!!!!
Good stuff dude! mines finished woop! gonna get it MOT'd next week and then taxed the week after :)
#189
Posted 24 June 2012 - 09:32 AM
#190
Posted 27 June 2012 - 05:41 PM
The body is tommorrows job!!!! :)
#191
Posted 28 June 2012 - 09:44 AM
#192
Posted 29 June 2012 - 01:42 PM
#193
Posted 29 June 2012 - 01:51 PM
#194
Posted 29 June 2012 - 08:18 PM
#195
Posted 30 June 2012 - 07:45 AM
Bing (1)
