Do I Need Lacquer?
Posted 09 June 2011 - 05:12 PM
Doing a little repair on my windscreen lip, and I'm going to have to spray most of it.
We've got some Halfords 'Filler primer' (Basically high build primer? ), and the paint (Halfords Rover electric blue).
Do I need some lacquer too?
I thought Halfords cans used to say if you needed lacquer to go on with the paint, but can't find any mention of lacquer at all on any of the current halfords cans we've got.
Posted 09 June 2011 - 07:43 PM
Posted 09 June 2011 - 09:22 PM
The whole car doesn't match altogethor anyway, it looks as though the doors have been resprayed at some point, and in certain lights, you can see that they're not quite the same colour as the rest of the car.
And seeing as its mostly going to be covered by the windscreen seal, its even less of a problem,
Posted 10 June 2011 - 04:06 PM
Posted 10 June 2011 - 04:09 PM
Posted 10 June 2011 - 06:59 PM
Posted 10 June 2011 - 08:08 PM
Do not sand, flat, nib or scotchbrite basecoat before laquering. Just let it air dry to a matt/satin finish and then laquer.
Posted 10 June 2011 - 08:15 PM
I'll spray it on and see how it looks, as I say, most of its going to be under the windscreen seal, so should be pretty well protected and won't be seen.
Thanks everyone
Posted 11 June 2011 - 01:10 AM
Only basecoat (all metallics and pearls, a few solids) need laquer.
Im presuming as you will whip the tops off some of the metalic bits?
Edited by Sam Walters, 11 June 2011 - 01:10 AM.
Posted 11 June 2011 - 05:54 PM
By the way, you can clearcoat over solid gloss colours too, which will provide better UV protection in most cases. Just dont sand or burn through the clear into the solid when polishing as your likely to get a colour difference.
