The 'as And When' Hornet Project
48 replies to this topic
#16 george66
george66
  • 49 posts
Posted 17 April 2013 - 03:46 PM
Well so much for trying to update every week, but, better late than never.
Managed to cut out the rear tunnel that didn't seem worth saving
And fit one from a wrote off MK3, after removing the square end and reshaping to round
Repair piece added in
Cleaned off and etch primed, still needs a bit of shaping, will do that when crossmember gets cut out, pop rivets holding it in place, will be removed when new cross member goes in
Welded in piece of 1x1 box section as a guide for lining up the tunnel, before cutting out the old one.
Seems to fit nicely at the crossmember
And to finish the day off, I made a couple of stiffeners, from some 1.7mm offcuts, for the new boot floor that will be going in
Hopefully it won't be another 4 weeks before I do the next update.
Edited by george66, 17 April 2013 - 03:47 PM.
#17 Gadgets
Gadgets
  • 471 posts
Posted 18 April 2013 - 05:45 AM
Keep going! every job you do is one less off the tick list!
#18 george66
george66
  • 49 posts
Posted 19 April 2013 - 02:56 PM
Got a couple of hours in today, cleaned up the remains of the old boot floor and dropped in the new one for a trial fit, it fell into place
Doesn't look too bad from this angle
This one hole doesn't quite line up properly. Have left original brackets on for lining up purposes
Spot on, on this side. Will know for definate when I lift subframe into place
Internal view
Not sure if I'm gonna use it or not, but, I do have a genuine boot floor, never fitted, complete with the fittings, extension and supports (seen at top of 1st picture), but it has been badly distorted through heat, as whoever welded the extension and supports, welded them continuously and along both edges, probably wouldn't have been too bad if it had been allowed to cool down between welds.
I may have a play around over the next couple of days and see how it fits and if it will straighten out.
Edited by george66, 20 April 2013 - 07:53 AM.
#19 george66
george66
  • 49 posts
Posted 30 April 2013 - 03:50 PM
Bit more done, thought I'd try and repair the rear lower corners, flattened the lip out
cut 2 pieces of metal and welded them together
Bent a new lip
other side and excess weld cleaned off
Lined up
Tacked in place
Welded, ground off, and finished with a 180 DA pad, suppose I should think about getting a 3" mini  sander for doing these jobs, 6" is too big for some places, still got the end to sort out at wheel arch, can do that when I replace the inner arch
Also decided  to go with the genuine boot floor that  I already had, here  it is showing it's distortion
Straight edge to show how bad it is
How much weld is needed to hold on a support bracket
Distorted piece cut off
Stiffener brackets zinc primed before welding in new piece
New piece is welded in place, just forgot to take a picture, will upload tomorrow if I get chance
#20 minimikej
minimikej
  • 347 posts
Posted 03 May 2013 - 10:41 PM
Quality fabrication and finishing, very impressed!
#21 jagman.2003
jagman.2003
  • 1,307 posts
  • Local Club: Owner of my own club of Minis
Posted 15 May 2013 - 07:46 AM
Coming along nicely.
#22 george66
george66
  • 49 posts
Posted 15 May 2013 - 06:51 PM
Not much done in the last couple of weeks, been helping a friend fit his kitchen, but every little helps
Boot floor repair that was done at last post update, need to remove and refit the rose with plug weld in stead of continuous weld
Small piece repaired below O/S/R light - before        After, have done the N/S/R as well
O/S/R boot floor to arch to rear backrest stiffener/strengthener repaired, just need to clean off the surface rust.
Arch%20to%20Boot%20to%20Rear%20Seat%20Re
Also made a start on repairing the lower back rest, have got half of this repair done, just not got anymore pics
Rear slam panel is also repaired and welded in place, again forgot the pics.
#23 george66
george66
  • 49 posts
Posted 25 August 2013 - 12:23 PM
Afternoon again,
it's been a while, so thought I'd better get some more done, not much, but intend for that to change this week, though, knowing my luck sommat will stop me
Managed to get out on Friday and chop off the O/S oversill
I then cut out the inner A-post and recycled one that I'd cut from from another shell
And today I welded in the A-post and step, and test fitted stiffener (also recycled), will leave grinding down plug welds till tomorrow.
Also got my new nuts n bolts delivered a while ago
#24 freaker
freaker
  • 1,378 posts
  • Local Club: mini fun club belguim
Posted 25 August 2013 - 01:19 PM
u used a part of your new boot floor to repair the old ?
or made a new piece for the old distorted one ?
freaker
#25 george66
george66
  • 49 posts
Posted 25 August 2013 - 01:31 PM
freaker
Made up a new piece, have still got the other boot panel, it might get sold on if my cousin doesn't need it
#26 freaker
freaker
  • 1,378 posts
Posted 25 August 2013 - 01:34 PM
if it doen`t get sold i may be up for it :)
freaker
#27 george66
george66
  • 49 posts
Posted 26 August 2013 - 03:32 PM
Bit more done today
Ground down the plug welds on the A-Post.
Cut out O/S floor pan and roughly fitted new one
Not sure if I should fit the heelboard before the floorpans or not, gonna have a browse of some other threads and see how others have done it
#28 ToM 2012
ToM 2012
  • 4,066 posts
Posted 06 October 2013 - 08:49 PM
wow! nice work we are pritty much replacing the same panels so i will keep a eye on how you clamp things together and what bits you do in order. thanks tom
#29 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 07 October 2013 - 05:51 AM
That is looking like a nice project and nice to see another Hornet being rebuilt :)
#30 Archived1
Archived1
  • Archived
  • 619 posts
Posted 05 November 2013 - 12:15 PM
Great work. Decent quality build. well done  :thumbsup:
