The 'as And When' Hornet Project
48 replies to this topic
#1 george66
george66
  • 49 posts
Posted 07 June 2011 - 10:22 PM
Evening all,
only registered here today, just over a week ago I bought a '67 - '68 Hornet.
Engine was seized when I bought it, but managed to free it and actually had it running for approx 30 secs, won't be run anymore until it's been out and had a look at.
This is my 1st attempt at anything this bad
This will be done 'as and when' I can, but hopefully within a year
as and when I can afford to spend money on it
as and when I can spare the time
as and when I feel like tinkering with it
as and when I can find some good metal to weld to
A few pictures for you
Boot
O/S/R window
N/S/R Floor
N/S/F floor
N/S vent - Flitch, O/S is same condition
O/S/R floor
O/S/F floor
Rear seat base
N/S inner wing
Edited by george66, 07 June 2011 - 10:25 PM.
#2 minidream94
minidream94
  • 1,233 posts
Posted 07 June 2011 - 10:29 PM
JESUS CHRIST :D you have one heck of a project on yoru hands there fella, but good luck >_<
#3 Amy_Green11
Amy_Green11
  • 31 posts
Posted 07 June 2011 - 10:35 PM
You are one brave man!
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,188 posts
  • Name: Neil
Posted 07 June 2011 - 10:52 PM
MMMmm i can see rust but no Hornet. I think there won't be much left of the original car left by the time this little beauty is finished. Good luck with it i hope you can weld??
#5 v21ash
v21ash
  • 421 posts
  • Local Club: HumbersideMiniClub.co.uk
Posted 07 June 2011 - 10:54 PM
Looks like you've got your hands full with that one :D Look forward to seeing the progress.
Mine started out as a 'as and when' project, 3 years later i'm still at it >_<
Welcome to TMF by the way.
#6 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 07 June 2011 - 10:55 PM
im actually thinking of doing one of these for my next project! good luck with it!
#7 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 07 June 2011 - 10:59 PM
Interesting project,
How did you unsieze the engine, oil down the bores?
#8 george66
george66
  • 49 posts
Posted 08 June 2011 - 08:09 AM
Not oil, but diesel, in hindsight, I should've used something thinner, maybe paraffin or penetrating oil.
Left it to soak for 3 days, then tried to free with a large spanner on the crankshaft, prybar through starter motor hole - it wouldn't budge
so off came the head, and a piece of 3x2 wood was shaved down to fit inside the bores, and struck a few times with a club hammer,
once the seal had been broken, more diesel in the bores over another 2 nights, while head was taken to local engineering place to have valve seats recut due to pitting.
A cheap headset - £8 +vat was bought to fire engine up for 1st time.
Head will need to come off again as it will need new valves, again due to corrosion around the stems.
I have access to a similar year Elf that is being broke, will try to use as much as I can, to keep as much originality as possible
#9 george66
george66
  • 49 posts
Posted 12 June 2011 - 12:45 PM
Got a bit further
Engine and subframe out
Front panels cut off
Subframe - seems to be in good condition, will find out after a good clean up
Edit:
Pictures resized
Edited by george66, 12 June 2011 - 02:26 PM.
#10 minimikej
minimikej
  • 355 posts
Posted 12 June 2011 - 05:20 PM
Looks like a good 'clean' project; you know where you are with this one.
I always loved Elves and Hornets - for some reason when they're done up all sporty they look a lot harder than Minis. If you go for replacing panels en masse, my advice is to go for original (Rover/NOS, BMH or M-Machine) where you can. Magnum panels just don't seem to fit...
#11 george66
george66
  • 49 posts
Posted 23 June 2011 - 03:17 PM
Finally managed to get it on a homemade rollover, a couple of builder's trestle's and scaffold pole, just need to widen the footprint of the trestle's a bit and maybe weld the scaffold clips as when they're tight, there is still quite a bit of movement in the clip joints.
Homemade spit
Made some templates for replacing the toeboard, there are 2 bolts at the top going through 2 holes either side, just below the crossmember.
Rear subframe removed, fit for the scrapheap
Awaiting delivery of gas tomorrow so I can brace door shuts etc etc
Edited by george66, 23 June 2011 - 03:18 PM.
#12 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 23 June 2011 - 03:29 PM
Cor good start - and it's a mark three, you doing it back in it's original colours.
I have to get mine started, waiting for my bonus to pay for panels and welding, just got to decide which one to do first!
or the cabrio...
Good luck! The hard bits to find are front panel, rear valence and bonnet!
Dave
#13 george66
george66
  • 49 posts
Posted 23 June 2011 - 04:33 PM
or the cabrio...
Dave
Hello,
yes I'll be doing it in original colours, I have access to an Elf that has very good front panels and will be using those, I'll also be keeping the remains of my front panel as the center section appears to be in good condition, my bonnet is good condition, rear valance and supports are no good at all, there was a seller on ebay (rupert_fish) who does the rear valance that goes for around £120, I have sent him a message to see if he will be relisting them
#14 george66
george66
  • 49 posts
Posted 18 March 2013 - 11:06 PM
Eighteen months after buying it, I've finally got the majority of panels I need to make a start, purchased from Mini Spares.
New panels include
N/S and O/S heritage inner wings
Radiator Cowl
N/S and O/S heritage Door Step and A Pillar repair
Boot Floor
O/S wing
Seat Crossmember
Scuttle repair ends
Various window seals, screen rubbers.
These are to add to other panels that I've already got, floor halves, arch's, companion bins etc, from M-Machine etc
After reading Tupers thread "Another Big One, '68 Hornet @ Mintec", it's just the kick up the rear end I need to get me going, there's no way I'll be able to keep up with him though.
Hoping to update this at least once a week
#15 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 20 March 2013 - 12:43 PM
cant wait to see the progress of this build
