L_jonez Micra Build
406 replies to this topic
#106 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,146 posts
  • Name: Sean
Posted 11 December 2011 - 09:28 PM
I quite fancy this conversion myself, nice work!!!
#107 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 11 December 2011 - 09:29 PM
me too, its planned for my clubvan estate
#108 l_jonez
l_jonez
  • 1,453 posts
Posted 12 December 2011 - 09:40 PM
engine started on its first crank, didnt even do a full rotation :D but then the carbs overflowed massively, looks like i need to sort the float levels
#109 l_jonez
l_jonez
  • 1,453 posts
Posted 15 December 2011 - 10:21 PM
Think I've sorted the carbs, they needed a strip and clean. Also the float levels where miles off.
Just hope it won't need to be looked at again .
Probably won't get chance to do any more now till after Xmas due to work etc
#110 vini
vini
  • 316 posts
  • Local Club: no never again
Posted 15 December 2011 - 10:34 PM
that engine looks well sexy sat in the frame,quite fancy the manifold too..Dean
#111 l_jonez
l_jonez
  • 1,453 posts
Posted 15 December 2011 - 11:20 PM
Thanks all my own work :) how's your mini coming along ?
#112 l_jonez
l_jonez
  • 1,453 posts
Posted 18 December 2011 - 02:40 PM
Quick video of it running with out a exhaust manifold :D
http://static.photob...e/VIDEO0014.mp4 http://static.photob...e/VIDEO0014.mp4
Edited by l_jonez, 18 December 2011 - 02:42 PM.
#113 l_jonez
l_jonez
  • 1,453 posts
Posted 19 December 2011 - 08:54 PM
Quick job today was to make some ht leads that had both a micra end and a Ford coil pack end
Standard micra leads on left, new connectors in center and modified & shortened leads on right.
Fitted
#114 evansisgreat
evansisgreat
  • 1,103 posts
  • Local Club: Not yet
Posted 22 December 2011 - 07:09 PM
Nice work mate, can't wait to hear it fired up!
#115 l_jonez
l_jonez
  • 1,453 posts
Posted 31 December 2011 - 02:08 PM
Another quick vid, it's a bit loud as the exhaust is not attached
http://static.photob...e/VIDEO0017.mp4
#116 malynch27
malynch27
  • 114 posts
Posted 02 January 2012 - 06:47 PM
Sounds awesome. Can't wait to see your comments on how she drives.
#117 l_jonez
l_jonez
  • 1,453 posts
Posted 02 January 2012 - 10:05 PM
Thanks, hopefully now that Xmas is over I can get on with it a bit more
Forgot to post a pic of the manifold now that it's been opened up a bit and smoothed out, will still need a final going over with fine wet&dry to get a better internal finish. Injector ports drilled and tapped to take push fit fittings (also treated to some jb weld for extra piece of mind ) for the vacume take offs
#118 fuzzy-hair-man
fuzzy-hair-man
  • 181 posts
  • Local Club: Minis in the Gong
Posted 03 January 2012 - 07:25 AM
Hey Dean,
I'm doing a Micra conversion myself at the moment in Australia, a large part of the subframe should be completed at the end of the week (less a couple of rails and finalizing engine mounts).
Anyway I was originally going to do a custom inlet manifold like Rids, but I like the look of the Toyota - Micra hybrid manifold.
So... just wondering what car and year was the Toyota manifold you got from? AFAIK it's a 4EFE but those engines in Australia at least seem to range up to 1.6 litres and none of the manifolds I've seen look like the one you've got there.
The 4EFE is Corolla and Starlet engines right?
Was there any reason you chose to ditch the Toyota manifold? Did it look like clearance to firewall was likely to be a problem?
Much thanks.
Congratulations on almost having completed your conversion, I'm excited about mine and I've only just started. I've learnt lots from BigChief's, Rid's Ian's and your threads thanks for posting!
I'll have to post mine once I have a bit more of interest, my subframe is a bit different hopefully giving me a bit more ground clearance and provision for a sumpguard.
#119 l_jonez
l_jonez
  • 1,453 posts
Posted 03 January 2012 - 08:34 AM
Pretty sure it was a 1.4 corolla engine. The main reason I ditched it was the carbs come up cheap and I much prefer being able to tune carbs and Megajolt
#120 fuzzy-hair-man
fuzzy-hair-man
  • 181 posts
Posted 03 January 2012 - 09:04 AM
OK, thanks I was hoping it wasn't a clearance problem that stopped you going down that path... :D
