L_jonez Micra Build
406 replies to this topic
#61 evansisgreat
evansisgreat
  • 1,103 posts
  • Local Club: Not yet
Posted 19 October 2011 - 09:23 PM
Nice one mate. Did you adapt the existing clutch pedal? I was wondering how practical it'd be to use an accelerator pedal. Mainly so I could use one of the dsn classics CNC ones, haha!
#62 l_jonez
l_jonez
  • 1,453 posts
Posted 19 October 2011 - 10:52 PM
Yep, will post pics when I get chance but its pretty much the same as rids
#63 l_jonez
l_jonez
  • 1,453 posts
Posted 23 October 2011 - 07:49 PM
As it stands
Bike carb + manifold - done
Exhaust manifold - done
Clutch - done
Rad - just a hose needed
Megajolt - waiting on trigger wheel
Left to do
Drive shafts
Lower suspension arm pins
Alternator
#64 rids
rids
  • 670 posts
Posted 24 October 2011 - 03:59 PM
where you putting alternator?
#65 l_jonez
l_jonez
  • 1,453 posts
Posted 24 October 2011 - 05:53 PM
It's going down the front of the engine
#66 l_jonez
l_jonez
  • 1,453 posts
Posted 25 October 2011 - 07:42 PM
Running a front mounted rad posed a problem the thermostat housing is forward facing which didn't allow room for a hose.
The solution... a mini thermostat housing :)
I was over the moon when I realised they had the same bolt pattern as the micra engine
#67 rids
rids
  • 670 posts
Posted 26 October 2011 - 06:04 PM
if you sourced an early one with a temp sender it would sort your temp gauge out too!
#68 l_jonez
l_jonez
  • 1,453 posts
Posted 26 October 2011 - 07:04 PM
Yeah that was the plan, the one on there now is just a spare I had laying around. What did you do for a sender ?
#69 rids
rids
  • 670 posts
Posted 26 October 2011 - 07:15 PM
next to the nissan sender there was another sender (for the carbon filter i think) if i remember right it's m18, i sleeved it to 5/16ths to suit a mini sender unit
#70 l_jonez
l_jonez
  • 1,453 posts
Posted 26 October 2011 - 07:21 PM
Ah that was my second plan! as I already have the taps from fitting senders to spi heads :) a early thermostat housing is just a simpler option if I can find one
#71 rids
rids
  • 670 posts
Posted 26 October 2011 - 07:28 PM
the sleeve i made dosn't allow the full length sender to sit in the coolant flow, however it does give a reading on the gauge but i'm concious it reads on the cool side. mines been running in all conditions since july and ive never had coolant issues. When do you hope to be finished?
#72 l_jonez
l_jonez
  • 1,453 posts
Posted 26 October 2011 - 07:47 PM
I don't really know I'm just doing a little bit when I can. It would nice if it was done by Xmas or at least all built up and ready to drop in the mini
#73 l_jonez
l_jonez
  • 1,453 posts
Posted 30 October 2011 - 06:19 PM
Forgot to post a pic of possible alternator position
It's all just tacked together for now until I can throw the suspension etc on and check for clearance.
#74 evansisgreat
evansisgreat
  • 1,103 posts
Posted 01 November 2011 - 10:54 PM
Are you having to run it backwards at the side or have you just done it because it's the easiest way? It's just other cg13 conversions run them behind or in front.
#75 l_jonez
l_jonez
  • 1,453 posts
Posted 02 November 2011 - 12:08 AM
Just the easiest location. It will run backwards which makes no difference as it creates a DC waveform
