L_jonez Micra Build
#31
Posted 15 July 2011 - 07:30 PM
#32
Posted 04 August 2011 - 09:59 PM
#33
Posted 04 August 2011 - 10:59 PM
#34
Posted 05 August 2011 - 12:19 AM
#35
Posted 06 August 2011 - 03:06 PM
#36
Posted 06 August 2011 - 03:30 PM
#37
Posted 08 August 2011 - 06:43 PM
It does mean I can take it off the road for the conversion etc with out worrying about getting to work so now I can really crack on but I can also take more time and make things look good aswell as functional
Just need to source some carbs now
#38
Posted 16 August 2011 - 08:28 PM
A quick look and the spacing is not to far off and can easily be corrected in the runners
#39
Posted 18 August 2011 - 01:39 AM
#40
Posted 27 August 2011 - 07:08 PM
#41
Posted 01 September 2011 - 10:53 AM
Remember that the 1ltr gear box and the 1.3 are very different in size, if you mock up with the 1ltr you'll find the 1.3 wont fit. Better to mock up the 1.3 initially.
The gear linkages are different as is the gearbox oil filler hole and the CV joints.
Only the very early 1.0L had the smaller box and driveshafts, if the engine and box are from the red Micra the box and driveshafts will be the same size as those from a 1.3L car.
What he said , its the same size box just different ratios
the boxes are difarent sises by a long shot i had this problem too but you can stick with the 1liter box flywheel and clutch on the 13 block ratios are a bit mental for the 13 but makes a very quick car but are limeted by gearing to around 110mph !!!
#42
Posted 02 September 2011 - 05:09 PM
110mph? what are the engine revs at that speed?
#43
Posted 07 September 2011 - 09:15 PM
#44
Posted 08 September 2011 - 07:59 PM
It's all just tacked for now and the center section of the cross member will be eventualy changed for some something better looking
#45
Posted 08 September 2011 - 08:47 PM
