L_jonez Micra Build
406 replies to this topic
#346 jonot2008
jonot2008
  • 26 posts
Posted 29 January 2014 - 01:22 AM
http://www.micra.org...-and-1-3.59195/
That's my thread over at MSC by the way
#347 Artstu
Artstu
  • 830 posts
Posted 29 January 2014 - 09:09 AM
I've never checked myself. Can you confirm you're using Mini Disc-brake CV's Jonot2008 ?
#348 jonot2008
jonot2008
  • 26 posts
Posted 29 January 2014 - 02:47 PM
Hi, yes I'm using standard disc brake cv's 19 splines inside
#349 Artstu
Artstu
  • 830 posts
Posted 29 January 2014 - 03:05 PM
Interesting, like you I remember it said that the outer end of the Micra shafts fitted the Mini CV joint, and I never thought to check.
photo from page 8 I think
Edited by Artstu, 29 January 2014 - 03:06 PM.
#350 jonot2008
jonot2008
  • 26 posts
Posted 29 January 2014 - 05:13 PM
That's the one, but my micra shafts have 21 splines -_- everything is from a 1.3 1999 micra
I don't understand what driveshafts I need to get a hold of :s
#351 Artstu
Artstu
  • 830 posts
Posted 29 January 2014 - 05:19 PM
Yes it's a bit weird because the Micra in this thread should have had the same shafts and gearbox (slightly different internals) as yours. The early 1.0L ones had the smaller box, shafts and joints, but I don't know if they fit the Mini CV's. but there's no mention of sourcing extra shafts in this thread  :unsure:
#352 l_jonez
l_jonez
  • 1,453 posts
Posted 29 January 2014 - 06:19 PM
Nope didn't source any other shafts. They are the ones that came out of the Micra, just shortened and welded back together they where sleeved as well just for extra strength.
#353 jonot2008
jonot2008
  • 26 posts
Posted 29 January 2014 - 07:04 PM
That's what I thought? So the later 1.0 micras must also have different shafts, unless it's just mine lol.
people on MSC say that the early 1.0 micras have 19 splines on outer part of shaft and the later 1.0 have 21 but obviously not as you (jones) have 19.
Edit: just seen your post at MSC, so that means inner cvs are the same then, just the outer part of the shaft I need to worry about -_-
Edited by jonot2008, 29 January 2014 - 07:19 PM.
#354 l_jonez
l_jonez
  • 1,453 posts
Posted 01 February 2014 - 09:14 PM
Ordered the microsquirt ecu today :-) its coming from the states so might be a week or two before I get my grubby hands on it
#355 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 01 February 2014 - 09:48 PM
How is the correct length worked out for cutting and welding the shafts ? One thing I have always wondered  :huh:
#356 l_jonez
l_jonez
  • 1,453 posts
Posted 01 February 2014 - 10:05 PM
There's a few ways of doing it, the route I took was
Cut shafts in half.
Put each end in the pot joint and CV joint.
Lined them up.
Clamped the 2 half's together.
Remove as one piece and measure the total length.
#357 smudger068
smudger068
  • 344 posts
Posted 02 February 2014 - 02:26 PM
Being nosey was it much more than the Megajolt system?
Am I correct in saying it can run injectors and ignition?
I have seen it but I feel im missing something due to the price of it
Or is just a new basic compact control system?
#358 l_jonez
l_jonez
  • 1,453 posts
Posted 02 February 2014 - 05:46 PM
With the current exchange rate its roughly £220 before shipping, not sure how much megajolt is these days Ive had mine 8 years.
Its basically a stripped down version of megasquirt and can run ignition and injectors.
#359 smudger068
smudger068
  • 344 posts
Posted 02 February 2014 - 06:05 PM
O you shipped from the states to make it cheaper
You still going to use the ford Edis coil setup?
What injectiors did you consider using?
Im going to watch this space see how you get on with it as I have some bike throttle bodies on a bike engined buggy I have that would be idle :)
#360 l_jonez
l_jonez
  • 1,453 posts
Posted 02 February 2014 - 06:29 PM
Yep going to keep the edis etc as its already in place so means only 2 wires to alter to get a crank input and run the ignition.
Injectors are the ones that came with my gsxr ITB's.
