L_jonez Micra Build
406 replies to this topic
#301 ibrooks
ibrooks
  • 1,017 posts
Posted 16 May 2013 - 02:45 PM
In theory moving them isn't a problem. If the resulting move moves the bottom ball joint backwards of forwards then it has changed the castor. You might be able to change the length of the arms to get the correct castor with them mounted in a different place. What they absolutely MUST be though is symmetrical.
Iain
#302 l_jonez
l_jonez
  • 1,453 posts
Posted 16 May 2013 - 05:04 PM
They pretty much got tho be in the correct position but Allspeed  do move the tie rod mounts then use adjustable tie rods to compensate
Do your self a favor and make a jig before cutting anything.
#303 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
  • Local Club: Weston Mini Muckers
Posted 16 May 2013 - 07:21 PM
yes don't do what I did and accidently cut the sodding sub frame in half! didn't bother with a jig wish I did now but the frame will work  after a lot of messing around!:)
#304 jonot2008
jonot2008
  • 26 posts
Posted 16 May 2013 - 08:02 PM
Ahh ok well i guess ill have to make a jig then, so the way it works is you make the jig around the subrame and bolt the tie rod mounts to the jig?
so they're in the right position as long as the jig is solid?
I think i could handle that, but i was out looking at the subframe earlier and the tie rod mounts are at an angle that id find difficult welding to the box section for the front section of the frame, also the diff casing out the back is going to be tight!! almost hits the bottom of the bulkhead/floorpan!
sorry if any of the questions seem stupid its just ive never done anything custom like this before, also i dont want to have to buy another subframe ;)
Thanks alot,
Jon
#305 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
Posted 16 May 2013 - 08:08 PM
cut the mounts off the mini frame and reuse them that's what I did
#306 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
Posted 16 May 2013 - 08:09 PM
http://i874.photobuc...zpsb952b395.jpg
#307 l_jonez
l_jonez
  • 1,453 posts
Posted 16 May 2013 - 08:46 PM
Make a jig (nice solid welds) around your frame and bolt it in.
if you look at the tie rod mounts they are welded onto the frame and can be cut off,  the front frame mounting point is incorporated into the tie rod mount, so once you have the bracket cut off the frame you can bolt it to the jig knowing its in the right place then build the frame around it
#308 jonot2008
jonot2008
  • 26 posts
Posted 16 May 2013 - 10:49 PM
Thanks alot everybody, ive got a lot better understanding now you mention the front mounts being on the tie rod mount.
ill make a jig as soon as i get the materials. ill let you know how i get on, would put a thread up but its going to be a slow one.
Also, for anyone still to have driveshafts made, i went looking at my old metro subframe earlier and the driveshafts are thinner than the mini ones,
so probably easier to make/ less to machine down. also means i can keep my mini driveshafts intact :)
Jon
#309 l_jonez
l_jonez
  • 1,453 posts
Posted 17 May 2013 - 07:45 AM
I used micra shafts, they use the same splines on the cv joints as the mini. It's a simple cut and weld job
Edited by l_jonez, 17 May 2013 - 07:47 AM.
#310 l_jonez
l_jonez
  • 1,453 posts
Posted 17 May 2013 - 08:00 AM
Looks like the ITB's line up well
#311 jonot2008
jonot2008
  • 26 posts
Posted 17 May 2013 - 07:45 PM
Ah went out today and removed micra cv's from driveshafts and mini cv's but they won't fit, micra shaft has 22 splines mini has 19 then read that the 1.0 has 19 but mines a 1.3 oh well, metro driveshafts it is. They actually like the same diameter, ill have to check with the vernier tomorrow.
#312 fuzzy-hair-man
fuzzy-hair-man
  • 181 posts
  • Local Club: Minis in the Gong
Posted 17 May 2013 - 11:47 PM
That's exciting!!! What are the throttle bodies from? I know Jenvey do some that can be used on the Micra but they were expensive.
They look to line up really well! Keep us informed with how it goes.
#313 l_jonez
l_jonez
  • 1,453 posts
Posted 18 May 2013 - 08:35 AM
Their from a Suzuki gsxr750
#314 fuzzy-hair-man
fuzzy-hair-man
  • 181 posts
Posted 18 May 2013 - 10:27 AM
Thanks, (I looked on your micra.uk thread just after posting :shy: )
Just curious how you go about selecting an appropriate size for throttle bodies or bike carbs?
As a guess:
the GSR-X Y(with injection) had a redline at 15500rpm (specs online) so 15500 x .750 means the engine flows 11625 litres per minute (that's a lot of air)
11625 / 1.275 = 9117 rpm.
So if the throttle bodies were the limiting factor in terms of flow(no reason to suspect this) on the micra you should be OK to 9117 rpm which is probably more than enough for anything other than an all out racer.
Or do you look at horse power delivered and as long as that matches your target your good, I guess it all comes down to airflow anyway.... might have answered my own question there...
#315 l_jonez
l_jonez
  • 1,453 posts
Posted 18 May 2013 - 10:55 AM
Pretty much answered it :) but I also looked at port spacing.
My engine is 1330 wich if I remember brings max rpm to 8.7 not that I'm ever going to hit that.
