Micra with built in cat
Rover k series manifold and down pipe which will be modified
Pics to follow
Posted 25 June 2011 - 06:35 PM
Posted 28 June 2011 - 05:47 PM
Posted 29 June 2011 - 07:21 AM
Posted 29 June 2011 - 09:19 AM
great work so far, keep it up! you could always cut the inlet manifold at an angle to give more room, cant it forwards a bit............towards the engine.... just a thought
Posted 10 July 2011 - 08:28 PM
Posted 11 July 2011 - 02:06 AM
Edited by bigchief3679, 11 July 2011 - 02:17 AM.
Posted 11 July 2011 - 03:16 PM
Posted 11 July 2011 - 03:32 PM
Edited by rids, 11 July 2011 - 04:05 PM.
Posted 11 July 2011 - 05:48 PM
i mounted o2 sensor after all 4 pipes join roughly just under sump level and it ran crap! if i rest o2 sensor between header pipes as they leave the cylinder head, the car runs sweet! i,m toying with mounting it into 1 of the header pipes about 12 inches from the head.
Posted 11 July 2011 - 06:26 PM
Edited by rids, 11 July 2011 - 06:30 PM.
Posted 11 July 2011 - 06:51 PM
Posted 11 July 2011 - 06:58 PM
Edited by rids, 11 July 2011 - 09:04 PM.
Posted 11 July 2011 - 09:54 PM
Posted 13 July 2011 - 08:11 PM
Posted 15 July 2011 - 12:51 AM
Forgot to post the pics to show the micra throttle body mounted to the Toyota manifold
I've spun around the throttle spindle/lever to allow the cable to be mounted to the manifold rather than use the micra bracket.
