L_jonez Micra Build
#241
Posted 26 September 2012 - 04:29 PM
#242
Posted 27 September 2012 - 06:37 PM
Here in western-europe these parts were fitted to N13 sunny's(pulsars in australia) with a CD17 engine. Unfortunately, here, they are no longer available new.
the correct numbers are 38101-50A03 for the crown wheel and 32241-51A03 or 32241-59Y13 for the mainshaft/pinion, the latter being the last known partnumber.
The other two numbers are not known in their computer, but it is likely they are the same spec, but fitted to a gearbox or model that we don't have in europe. or like you say the first number discontinued and replaced by the second, although no info was found on that.
#243
Posted 27 September 2012 - 07:02 PM
#244
Posted 27 September 2012 - 08:45 PM
#245
Posted 28 September 2012 - 12:27 AM
Were you able to verify the gearing?
#246
Posted 28 September 2012 - 09:44 AM
"overbrengingsverhouding" means gear-ratio and "eindoverbrenging" means final drive.
Not much differrence between the two.
#247
Posted 28 September 2012 - 09:56 AM
Edited by Artstu, 28 September 2012 - 09:57 AM.
#248
Posted 28 September 2012 - 12:54 PM
But like i said yesterday, chances are, that in other parts of the world a 3.55 final drive was fitted. unfortunately they are not mentioned in the manual. Maybe in the N12/B11, but the manual of those seems to be MIA.
#249
Posted 29 September 2012 - 10:55 AM
When I graph the revs the standard diff in 5th is about half way between 4th and 5th on the 3.55 diff, so in one way you're gaining an extra 1/2 a gear, the Micra boys are looking at taller than standard diff ratios to make highway cruisers and the 3.55 only just brings the 10" mini up to similar revs to standard...
L_Jonez we're kind of polluting your thread here, if you like we could probably take it elsewhere...
#250
Posted 29 September 2012 - 03:01 PM
#251
Posted 30 September 2012 - 09:03 AM
#252
Posted 28 October 2012 - 12:15 PM
the more ive drove mine this year the more i think i'll stick with the standard box. i like the acceleration and cruising between 70 and 80 is quick enough
same here, i think the main problem is im used to driving a diesel 200-odd miles a day so rarely pass 3k rpm plus the bike carbs make everything very loud
i run the higher 4.6:1 final drive which make it worse BUT hopefully the box with the 3.8:1 will go in soon, just witing for a chance to actually assemble the engine
#253
Posted 11 November 2012 - 09:13 PM
hopefully tomorrow i can fit the damn thing
#254
Posted 12 November 2012 - 02:20 PM
Hopefully the damn thing will pull like a train, and be damn fast.
#255
Posted 12 November 2012 - 10:17 PM
give it another go tomorrow with a charged battery
Bing (1)
