L_jonez Micra Build
406 replies to this topic
#196 l_jonez
l_jonez
  • 1,453 posts
Posted 29 May 2012 - 10:54 PM
You would have to do some research into different models of micra and see if any have a lower fd.
#197 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
  • Local Club: Weston Mini Muckers
Posted 07 June 2012 - 10:19 PM
hello was just seeing how u did your ignition on the engine as just looking in to it now??
cheers
luke
#198 l_jonez
l_jonez
  • 1,453 posts
Posted 07 June 2012 - 10:36 PM
I use Megajolt, which i already had on the mini. Just fitted the trigger wheel to the crank pully and re-mounted the coil pack.
#199 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
Posted 08 June 2012 - 12:04 AM
cheers buddy got a 1999 engine that i wnt to run on weber carbs so trying to figue out the best way
#200 l_jonez
l_jonez
  • 1,453 posts
Posted 08 June 2012 - 08:36 AM
There won't be much room for webbers but I'd love to see that.
Heres how i mounted the trigger wheel
Im sure bigcheif has used a mini dizzy might be worth going through the big thread
#201 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
Posted 08 June 2012 - 03:42 PM
thanks mate photo is perfect and yeh we will make room for webers lmao!
#202 l_jonez
l_jonez
  • 1,453 posts
Posted 25 July 2012 - 09:39 PM
Really enjoying the mini now, been suppressing alot of modern car drivers . 1.3 lump now has a new clutch and is waiting to drop in just need some time (well a few hours)
#203 rids
rids
  • 670 posts
Posted 26 July 2012 - 06:40 PM
I know i'm biased but I'm really impressed with this engine in a mini. a smile every drive
#204 Tomm
Tomm
  • 2,462 posts
Posted 27 July 2012 - 11:01 AM
Couldn't agree with you more, I love mine!
This is a very impressive and tidy build. What are your power expectations for this motor?
I currently have a 80bhp (well 79.8 i think) 1.0 and I am told that the 1.3 lumps fit straight in.
#205 l_jonez
l_jonez
  • 1,453 posts
Posted 27 July 2012 - 04:23 PM
I'm hoping for around the 100bhp mark
#206 rids
rids
  • 670 posts
Posted 27 July 2012 - 05:07 PM
do the 1.0's really have that much?
#207 l_jonez
l_jonez
  • 1,453 posts
Posted 27 July 2012 - 10:05 PM
They can do, mine is probably around that power range
#208 rids
rids
  • 670 posts
Posted 28 July 2012 - 08:47 AM
I'll be interested to here the difference between the two sizes, i may be doing another 1, this is my sons daily driver and i'm getting itchy fingers. it was bought off here and has no inner wings as it was gonna have a flip front fitted.
#209 l_jonez
l_jonez
  • 1,453 posts
Posted 13 August 2012 - 04:41 PM
forgot to post some of the progress a while back ..... whilst i had the new gearbox stripped i decided to modify the casing a bit. the problem i had was with my frame it was near impossible to remove the speedo drive to fill the box with oil.
so what ive done is drilled and tapped the top of the gearbox and fitted a m10 (could not find a bigger tap :( ) bolt as a plug. so hopefully now when the box goes in i can remove the plug and via a funnel fill the box with ease
rubbish phone pic
#210 Tomm
Tomm
  • 2,462 posts
Posted 15 August 2012 - 11:08 PM
Love this Jonez.
Hopefully one day my bay will look as tidy as yours!
Interesting read on the gearbox filler modification, will have to have a look at mine in the morning.
