L_jonez Micra Build
#181
Posted 11 May 2012 - 07:20 PM
#182
Posted 11 May 2012 - 07:27 PM
#183
Posted 11 May 2012 - 08:29 PM
#184
Posted 11 May 2012 - 09:54 PM
i think my next step is almera box and some camsI ditched my servo and realised its much better without it. You can fit almera gearbox which has a much lower final drive which might be suited to 10's
#185
Posted 21 May 2012 - 10:22 PM
#186
Posted 22 May 2012 - 07:30 PM
#187
Posted 22 May 2012 - 09:52 PM
The CG10DE has 3774 @ 100kph on 10's, 3654 @ 100kph on 12's, and 3394 @ 100kph on 13's. (5th, CG10DE gearbox, and 4.05 final drive)
Given a difference of 100 rpm at 100km/hr I'm going to keep my 10's.
The Almera Diesel final drive of 3.55:1 would give 2941 rpm @ 100kph on 10's in 5th using the CG13DE gearbox.
I figure the CG13DE is a high revving engine so 3200 at 100km is not so bad... Of course it all depends on the tyre sizes you choose but the sizes I used came from pretty standard fitting mini tyres.
Edited by fuzzy-hair-man, 22 May 2012 - 11:00 PM.
#188
Posted 22 May 2012 - 11:04 PM
#189
Posted 23 May 2012 - 01:38 AM
Apparently the later cg10 box that i got (98-00) has a 4.65 fd
Ouch! my calculator has yours doing 4333 @ 100 on 10's
Does that tie in with what you get? or perhaps they changed your gear ratios as well? Seems a lot of revs...
#190
Posted 23 May 2012 - 11:56 AM
#191
Posted 23 May 2012 - 02:40 PM
Posted 23 May 2012 - 04:49 PM
The rev limit is about 6200rpm but it can be removed.
#193
Posted 23 May 2012 - 08:36 PM
Edited by MiniElliott, 23 May 2012 - 08:37 PM.
#194
Posted 23 May 2012 - 09:19 PM
The 3.55 fd from a Almera diesel has about the same effect on 10's as fitting 13's with the std 1.3 diff according to my spreadsheet, I've no chance of finding one in Australia though as they never made it here.
Edited by fuzzy-hair-man, 23 May 2012 - 09:53 PM.
#195
Posted 23 May 2012 - 10:25 PM
