6 Blade (metal) Radiator Fan Fitting Problem?
22 replies to this topic
#16 maccers
maccers
  • 1,867 posts
  • Local Club: LSMOC
Posted 21 June 2013 - 02:24 PM
Thanks for the pics Barman. Used to stay in Pafos all the time when visiting Cyprus, love it there! Coral Bay area....
Edited by maccers, 21 June 2013 - 02:24 PM.
#17 GraemeC
GraemeC
  • 7,438 posts
Posted 21 June 2013 - 02:31 PM
Being a GT, Barman's car probably has longer upper and lower rad brackets as well as the obviously the much thicker fan spacer.
Such a thick spacer on a roundnose set up would probably push the fan into the radiator core.
#18 Barman
Barman
  • 1,068 posts
Posted 21 June 2013 - 02:48 PM
Not too far from me... and my daughter lives in Epsom!
#19 maccers
maccers
  • 1,867 posts
  • Local Club: LSMOC
Posted 21 June 2013 - 03:17 PM
Yep, mines a round nose so wont be using such a big spacer, but enough to clear the blades from the super charger pully! Fitting alloy 2 core rad to replace steel 2 core to see if it lowers temp any.
Epsom is not getting as much sunshine thats for sure!
#20 Barman
Barman
  • 1,068 posts
Posted 21 June 2013 - 03:43 PM
It is roasting here today... took her for another long run and am very pleased with the cooling....
#21 smev
smev
  • 162 posts
  • Local Club: P&S MOC
Posted 21 June 2013 - 08:05 PM
What thickness is the alloy and steel 2 core rads?
I have a 4 core in mine, it seems the same size as a standard 3...but I was wondering if these are too thick and I need a 2 core.
#22 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 21 June 2013 - 08:28 PM
  4 core rads are massive.  Most 2 cores are the same size as 3 cores.
#23 62S
62S
  • 1,243 posts
  • Local Club: You must be joking!
Posted 21 June 2013 - 08:32 PM
There was a batch of these fans produced with the mounting holes too small for the standard bolts.
