Posted 31 May 2011 - 07:20 PM
I defer to Roy on the ACR model alternators. However, to be SAFE, you should include a warning light for any alternator you use if the car it came from used a warning light.
The lamp does not "draw" current as such in this installation. The way the light works is current flows from the ignition switch, through the lamp, through the field coils in the alternator and to earth. When you turn the key to start the engine, current flows through the lamp and alternator field coils which both powers the light and charges up the alternator field coils. Once the alternator starts producing electricity, it self-energizes its field coils. This brings the "small terminal" on the alternator up to charging system potential. Since both sides of the lamp are now at charge system potential the warning lamp goes out. (No voltage difference across the bulb).
Can you use an LED? Generally "no", at least not by itself. LEDs do not allow sufficient current to flow through themselves for the alternator field coils to charge up. HOWEVER, there is an easy work around. Start with the "normal" warning lamp configuration where a white wire goes from the ignition switch, to the lamp, out the lamp via a brown/yellow wire and finally off to the alternator. Replace the warning lamp with a 40 Ohm power resistor (something rated for at least 1 Watt). NOW get your LED lamp assembly. A plain LED will need a "dropping resistor", typically 1000 Ohms. A pre-configured LED warning lamp will already have this resistor inside. Take your LED lamp (or LED with dropping resistor) and wire it in PARALLEL with the 40 Ohm power resistor. Pay attention to the polarity or the LED will not light. With the LED wired in parallel to the 40 Watt resistor... the LED will turn on and off just like a normal incandescent light. However, the current required to power the alternator field coils on startup will pass through the 40 Watt resistor.
