K&n Air Filters
Posted 31 May 2011 - 01:23 PM
I have recently bought a K&N filter and just wondering if someone could point me in the right direction of this PDF file as i have not been able to find it again!
Danke.
Posted 31 May 2011 - 03:18 PM
Most mpi owners use flexible tubing to feed the cold air from the grille to the filter, such as a k&n which it bolted to the throttle body. However you can make you own unique ducting with a bit of large diameter silicon hose and some aluminium tubing. You can bolt a cone filter on one end (which is then located behind the grille) mean while bolt the other end on to the throttle body.
You'll have to watch what size hose / tubing you buy as there isn't much space between the brake servo and the rocket cover! Lol
Posted 02 June 2011 - 08:31 AM
Posted 02 June 2011 - 04:07 PM
Posted 02 June 2011 - 04:21 PM
Posted 17 December 2012 - 11:37 PM
Since without a cold air intake the air is drawn from the area behind the engine where the exhaust manifold is, it makes sense if you think about it for more than 20 seconds.
Posted 17 December 2012 - 11:45 PM
Edited by jaydee, 18 December 2012 - 12:21 AM.
Posted 18 December 2012 - 12:10 AM
blanking off the inlets run cooler
Posted 18 December 2012 - 12:22 AM
Posted 18 December 2012 - 05:59 PM
Also if the temperature of the intake air was not relevant, why would rover have put an air intake temperature sensor in the intake which contributes (according to sprocket) about 20% of the data for the fuel mix?
People are too quick to dismiss things like cold air intakes, if they didn't make a difference, why would all modern production cars come with them?!
EDIT: I forgot to put the graph in...
Edited by northy, 18 December 2012 - 06:07 PM.
